2011-06-04, 08:03
I have added the cleanonupdate bit to my advancedsettings file and yet it doesn't seem to do anything.
I have enabled update library on startup, and verified that it does indeed update by adding a movie and xbmc picks it up and adds it to the library. However, when I remove a movie via deletion at my server (not through xbmc), and reboot xbmc it does NOT remove the movie from the library.
There is no error reported in my log file relating to cleanonupdate.
If I manually clean the library it works just fine and removes the movie.
Any ideas or is this a known issue?
<advancedsettings>
<videolibrary>
<cleanonupdate>true</cleanonupdate>
</videolibrary>
<videoextensions>
<add>.html</add>
</videoextensions>
</advancedsettings>
