Full Version: TV Tunes not playing while in Library on Apple TV 1
Hi Guys,
Wondering if you can give me some advice here. I used the add on to download the tunes and enabled it in the Carmichael but they are not playing when i browse. The files are on an SMB share and the tunes are in the root folder of tv shows labeled theme.mp3. Here is the log file when i go into the tv show library.
10:00:37 T:2684407808 M: 26181632 NOTICE: Samba is idle. Closing the remaining connections
10:00:51 T:2684407808 M: 49180672 NOTICE: ES: Starting event server
10:00:54 T:2684407808 M: 49115136 NOTICE: Enabled debug logging due to GUI setting. Level 2.
10:01:03 T:2684407808 M: 48803840 DEBUG: CGUIWindowManager:TonguereviousWindow: Deactivate
10:01:03 T:2684407808 M: 48799744 DEBUG: ------ Window Deinit (SettingsCategory.xml) ------
10:01:03 T:2684407808 M: 48820224 DEBUG: CGUIWindowManager:TonguereviousWindow: Activate new
10:01:03 T:2684407808 M: 48816128 DEBUG: ------ Window Init (Settings.xml) ------
10:01:03 T:2684407808 M: 48820224 INFO: Loading skin file: Settings.xml
10:01:08 T:2684407808 M: 16969728 DEBUG: CGUIWindowManager:TonguereviousWindow: Deactivate
10:01:08 T:2684407808 M: 16982016 DEBUG: ------ Window Deinit (Settings.xml) ------
10:01:08 T:2684407808 M: 16998400 DEBUG: CGUIWindowManager:TonguereviousWindow: Activate new
10:01:08 T:2684407808 M: 16998400 DEBUG: ------ Window Init (Home.xml) ------
10:01:08 T:2684407808 M: 16998400 INFO: Loading skin file: Home.xml
10:01:08 T:2684407808 M: 16990208 WARNING: Skin has invalid include: Global_RSS
10:01:11 T:2684407808 M: 50077696 DEBUG: Loading: /mnt/Scratch/Users/frontrow/Applications/XBMC.app/Contents/Resources/XBMC/system/ImageLib-x86-osx.so
10:01:13 T:268899840 M: 43859968 DEBUG: thread start, auto delete: 1
10:01:15 T:2684407808 M: 39096320 DEBUG: Previous line repeats 1 times.
10:01:15 T:2684407808 M: 39096320 DEBUG: ExecuteXBMCAction : Translating XBMC.ActivateWindow(MyVideoLibrary,tvshowtitles,return)
10:01:15 T:2684407808 M: 39104512 DEBUG: ExecuteXBMCAction : To XBMC.ActivateWindow(MyVideoLibrary,tvshowtitles,return)
10:01:15 T:2684407808 M: 39104512 DEBUG: Activating window ID: 10025
10:01:15 T:2684407808 M: 39104512 DEBUG: Checking if window ID 10024 is locked.
10:01:15 T:2684407808 M: 39104512 DEBUG: ------ Window Deinit (Home.xml) ------
10:01:16 T:2684407808 M: 39092224 DEBUG: ------ Window Init (MyVideoNav.xml) ------
10:01:16 T:2684407808 M: 39092224 INFO: Loading skin file: MyVideoNav.xml
10:01:16 T:2684407808 M: 39084032 WARNING: Skin has invalid include: Animation_CommonFade
10:01:16 T:2684407808 M: 39092224 WARNING: Previous line repeats 7 times.
10:01:16 T:2684407808 M: 39092224 WARNING: Skin has invalid include: Animation_ZoomInZoomOut
10:01:16 T:2684407808 M: 39088128 WARNING: Skin has invalid include: Animation_CommonFade
10:01:16 T:2684407808 M: 39088128 WARNING: Skin has invalid include: Animation_ZoomInZoomOut
10:01:16 T:2684407808 M: 39088128 WARNING: Previous line repeats 2 times.
10:01:16 T:2684407808 M: 39088128 WARNING: Skin has invalid include: detailcolornofocus
10:01:16 T:2684407808 M: 39088128 WARNING: Previous line repeats 5 times.
10:01:16 T:2684407808 M: 39088128 WARNING: Skin has invalid include: Animation_HideShowcase
10:01:16 T:2684407808 M: 38895616 DEBUG: CGUIMediaWindow::GetDirectory (videodb://2/2/)
10:01:16 T:2684407808 M: 38912000 DEBUG: ParentPath = [videodb://2/2/]
10:01:16 T:2684407808 M: 38858752 DEBUG: GetTvShowsByWhere query: SELECT tvshow.*,path.strPath AS strPath,counts.totalcount AS totalCount,counts.watchedcount AS watchedCount,counts.totalcount=counts.watchedcount AS watched FROM tvshow JOIN tvshowlinkpath ON tvshow.idShow=tvshowlinkpath.idShow JOIN path ON path.idpath=tvshowlinkpath.idPath LEFT OUTER join ( SELECT tvshow.idShow AS idShow,count(1) AS totalcount,count(files.playCount) AS watchedcount FROM tvshow JOIN tvshowlinkepisode ON tvshow.idShow=tvshowlinkepisode.idShow JOIN episode ON episode.idEpisode=tvshowlinkepisode.idEpisode JOIN files ON files.idFile=episode.idFile GROUP BY tvshow.idShow) counts ON tvshow.idShow=counts.idShow
10:01:16 T:2684407808 M: 38821888 DEBUG: Time for actual SQL query = 136
10:01:16 T:2684407808 M: 38838272 DEBUG: Time to retrieve tvshows from dataset = 51
10:01:16 T:2684407808 M: 38891520 DEBUG: Saving fileitems [videodb://2/2/]
10:01:16 T:2684407808 M: 38641664 DEBUG: -- items: 64, sort method: 25, ascending: true
10:01:16 T:268674560 M: 38645760 DEBUG: thread start, auto delete: 0
10:01:16 T:268674560 M: 38875136 DEBUG: OpenDir - Using authentication url smb://SZUCSSERVER/Music/JON%2dPC/G/MP3%27S/TV%20Shows/Beast%20Hunter
10:01:17 T:268674560 M: 23474176 DEBUG: OpenDir - Using authentication url smb://SZUCSSERVER/Music/JON%2dPC/G/MP3%27S/TV%20Shows/Community
10:01:17 T:268674560 M: 23449600 DEBUG: OpenDir - Using authentication url smb://SZUCSSERVER/Music/JON%2dPC/G/MP3%27S/TV%20Shows/David%20Letterman
10:01:17 T:2684407808 M: 40546304 DEBUG: ExecuteXBMCAction : Translating XBMC.RunScript(script.TvTunes,backend=True&loop=True)
10:01:17 T:2684407808 M: 40542208 DEBUG: ExecuteXBMCAction : To XBMC.RunScript(script.TvTunes,backend=True&loop=True)
10:01:17 T:2684407808 M: 40546304 ERROR: Python script "script.TvTunes" does not exist
10:01:17 T:2684407808 M: 40542208 DEBUG: ExecuteXBMCAction : Translating SetFocus(50)
10:01:17 T:2684407808 M: 40546304 DEBUG: ExecuteXBMCAction : To SetFocus(50)
10:01:17 T:268674560 M: 37543936 DEBUG: OpenDir - Using authentication url smb://SZUCSSERVER/Music/JON%2dPC/G/MP3%27S/TV%20Shows/Grey%27s%20Anatomy
10:01:17 T:270264320 M: 38948864 DEBUG: DoWork - took 481 ms to load special://masterprofile/Thumbnails/Video/Fanart/3d492522.tbn
10:01:17 T:268674560 M: 38948864 DEBUG: OpenDir - Using authentication url smb://SZUCSSERVER/Music/JON%2dPC/G/MP3%27S/TV%20Shows/MacGyver
10:01:17 T:268674560 M: 34705408 DEBUG: OpenDir - Using authentication url smb://SZUCSSERVER/Music/JON%2dPC/G/MP3%27S/TV%20Shows/The%20Muppet%20Show
10:01:17 T:268674560 M: 34705408 DEBUG: OpenDir - Using authentication url smb://SZUCSSERVER/Music/JON%2dPC/G/MP3%27S/TV%20Shows/The%20Office%20%28US%29
10:01:17 T:268674560 M: 34705408 DEBUG: OpenDir - Using authentication url smb://SZUCSSERVER/Music/JON%2dPC/G/MP3%27S/TV%20Shows/Operation%20Repo
10:01:17 T:268674560 M: 34705408 DEBUG: OpenDir - Using authentication url smb://SZUCSSERVER/Music/JON%2dPC/G/MP3%27S/TV%20Shows/Documentaries
10:01:17 T:268674560 M: 34701312 DEBUG: OpenDir - Using authentication url smb://SZUCSSERVER/Music/JON%2dPC/G/MP3%27S/TV%20Shows/samantha%20Who
10:01:17 T:268674560 M: 34701312 DEBUG: OpenDir - Using authentication url smb://SZUCSSERVER/Music/JON%2dPC/G/MP3%27S/TV%20Shows/Saturday%20Night%20Live
10:01:17 T:268674560 M: 34701312 DEBUG: OpenDir - Using authentication url smb://SZUCSSERVER/Music/JON%2dPC/G/MP3%27S/TV%20Shows/Scrubs
10:01:17 T:268674560 M: 34701312 DEBUG: OpenDir - Using authentication url smb://SZUCSSERVER/Music/JON%2dPC/G/MP3%27S/TV%20Shows/The%2eStarter%2eWife
10:01:18 T:268674560 M: 34701312 DEBUG: OpenDir - Using authentication url smb://SZUCSSERVER/Music/JON%2dPC/G/MP3%27S/TV%20Shows/Tom%20%26%20Jerry
10:01:18 T:268674560 M: 34697216 DEBUG: OpenDir - Using authentication url smb://SZUCSSERVER/Music/JON%2dPC/G/MP3%27S/TV%20Shows/The%20Tom%20and%20Jerry%20Show
10:01:18 T:268674560 M: 34697216 DEBUG: OpenDir - Using authentication url smb://SZUCSSERVER/Music/JON%2dPC/G/MP3%27S/TV%20Shows/Wings
10:01:18 T:268674560 M: 34697216 DEBUG: OpenDir - Using authentication url smb://SZUCSSERVER/Music/JON%2dPC/G/MP3%27S/TV%20Shows/WWE
10:01:18 T:268674560 M: 34697216 DEBUG: Thread 268674560 terminating
10:01:18 T:2684407808 M: 42414080 INFO: CheckIdle - Closing session to http://feeds.feedburner.com (easy=0xb9d2000, multi=0xc610ed0)
Thanks for your help
