I'll get a log up later today.
Upgraded to ODK40 yesterday and playing music is broken.
I've tried MP3s that are on an SMB share and Last.fm. Both cause XBMC to crash/exit and restart. LiveTV is working fine.
Log -
http://pastebin.com/fbFXBfEb
This happened on a really old 9.10 Lucid installation but the log file is from a brand new 10.04 Maverick installation.
libmad.so?
Fixed.
apt-get install libmad0
Also anything not directly related to PVR should not be posted in here and preferably tested on normal xbmc as well
I wasn't to know if it wasn't PVR related. But fair point.
As a golden rule if the option is available in normal XBMC its not pvr related unless it works on that and not in the pvr builds
Jezz_X Wrote:As a golden rule if the option is available in normal XBMC its not pvr related unless it works on that and not in the pvr builds
I realise that but it's a bit difficult (and fairly pointless) running two separate versions of XBMC on the same system when I'm not a developer.
Either way, I didn't waste anyone's time because I diagnosed and fixed the problem myself.
