2012-03-18, 19:03
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46
2012-03-18, 19:14
(2012-03-18, 19:03)RicardoFonseca Wrote: [ -> ]Thanks Mudislander!
I'll go try.
make sure that you've downloaded and installed Frost's XBMC Intro Move Addon
2012-03-18, 20:36
(2012-03-18, 19:14)Mudislander Wrote: [ -> ]make sure that you've downloaded and installed Frost's XBMC Intro Move Addon
Of corse!... lol
Works well, for now.
2012-03-19, 20:05
Great Skin!!
How do I go about adding Hibernate as an option to the shutdown menu? Switching Standby to Hibernate would also work for me as well.
2012-03-21, 04:21
Love this skin. 1 issue that I am having though.
I have set the background as multi and pointed it to a fanart folder on my NAS server, I am useing Artwork Organizer to copy my fanart to this folder. I copies over .tbn files for movies/tv shows. In the log I get this message from the skin:
22:17:42 T:207577088 WARNING: JpegIO: Error 55: Not a JPEG file: starts with 0x%02x 0x%02x
22:17:42 T:207577088 ERROR: Texture manager unable to load file: special://masterprofile/Thumbnails/5/5bc11cab.tbn
22:17:53 T:138592256 WARNING: JpegIO: Error 55: Not a JPEG file: starts with 0x%02x 0x%02x
22:17:53 T:138592256 ERROR: Texture manager unable to load file: special://masterprofile/Thumbnails/b/bd44e39c.tbn
It seems it does not like these fanart files. What program should I be using to get a folder full of fanart .JPEG files then? I thought I did this with other skins and it worked, am I doing something wrong?
2012-03-21, 09:57
You can export your library in single mode..then you should have a folder containing your thumbs and fanart...I think it's best to pick it from there...
mad-max
mad-max
2012-03-23, 11:27
Hello max
sorry for my english
congratulations for your project is really great I tried it and it works great I wanted to ask if you could tell me how to do and what files. xml I need to change to add two new pulsnati main menu (cartoon-documenteri) using the skin Confluence simple as taking as the "film" and then I wanted to change the submenu button changing from movie trailer actors etc ... with genres such as horror films - action - comedy, etc ...
can you help? thank you very much
2012-03-27, 02:02
hi,
First off, I'm loving this skin and is flexibility ... great job!
Is there anyway to make the coverwall vizualization folder setting recursive so that I could set it to
./userdata/Thumbnails/Music
and it would find all the cached thumbnails and would always be up to date whenever xbmc finds and stores new albumarts here
thanks
thanks
2012-03-27, 08:39
(2012-03-27, 02:02)pomdave Wrote: [ -> ]Is there anyway to make the coverwall vizualization folder setting recursive so that I could set it toNope...unfortunately this is not possible as the multiimage control for the covverwall can't be recursive
2012-03-27, 17:54
Not sure if this was covered already. I did search the thread ..
When Fast Forwarding there is no indication of the speed your FF. Usually there's a 2x, 4x, etc etc.
Also is there a way so that the TV Show Recently added is the same size as the Movie ones? I can see like 4 of the recently added movies but because the recently added TV shows use larger thumbnail it will only display like 2.
THanks!
THanks!
2012-03-27, 19:28
The fast forward thing already came up a bit earlier...
I know that these are currently not showing and yes it will get implemented, but this is after the wedding...
The Recently added issue can be easily solved...
Take a look at "IncludesRecentlyAdded.xml" in the skin folder and c&p the part from videos to tvshows...then adjust the position to your liking and you're done...
2012-03-27, 19:56
(2012-03-27, 19:28)mad-max Wrote: [ -> ]The fast forward thing already came up a bit earlier...
Rep points sent!. Thank you very much!..
2012-03-27, 22:04
MM,
Do you have the exact path for that "IncludesRecentlyAdded.xml". I can't seem to locate it. Im running win7 and have searched the XBMC Folder in Program files(x86) as well as the appdata folder.
I did find a "IncludesHomeRecentlyAdded.xml". Is that it?
2012-03-27, 22:55
@dysan:
Yes, that's it...could not really take a look before as my post was tapatalked while taking a walk with the dog
But it should fit now...
If you still have problems, just let me know...
mad-max
mad-max
2012-03-28, 08:19
Hi max,
I tried the recently added file in your git hub, in excghanged it with the IncludesRecentlyAdded.xml and it's still the same, i don't have 4 movies or extra tv shows. any ideas what iv'e done wrong.
danke
danke
