Ok folks...released 1.0.1
Changelog:
- fixed codec flag for video resolution
- fixed pause label in DialogSeekBar.xml
- fixed concert button to go directly into titles
- fixed bug in Home.xml with turned on vis and colordiffuse
- fixed bug that prevented showing the source flag in VideoFullScreen.xml while pressing "i" or "m"
- fixed some issues in VideoFullScreen.xml for LiveTV
- rearranged infos and added logo.png-support for Rightlist (TVShows)
- added "recently added albums" to home screen
- added "latest-concerts" widget in home-screen
- updated English/strings.xml
New Screenshots can be found here(at the bottom of the thread):
http://www.xbmcnerds.com/index.php?page=...ostID=9539
Next on to do:
- support for 3D flag
- more custom home items
- trailer availability in viewtype showcase
- maybe the deck support on home (like the idea), let's see...
Hope you like it...
BTW: Looking for translators that translate the 40 new strings from the mod in different languages...everbody who is interested: please pm me
cheers,
mad-max
In "Right list" TV shows view when some shows have logos downloaded and others don't, shows without logos display logos from previously selected shows that have them.
E.g. if "Boardwalk Empire" has a logo and "Bones" does not, when moving from 1-st to 2-nd you will still see the "Boardwalk Empire" logo on "Bones" view.
PS. Can do a Russian translation, if necessary.
Roman_V_M Wrote:In "Right list" TV shows view when some shows have logos downloaded and others don't, shows without logos display logos from previously selected shows that have them.
Thanks for the hint...will take a look...
if you could post the translated strings that would be awesome...
mm
Hello ...
I have a request about recently added ...
Is it possible to have an option to :
- center widgets on home screen
- have more than 2 or 3 latest items ( 5 centered , like "default eden-confluence" will be enough for me
thanks ...
mardup Wrote:Hello ...
- have more than 2 or 3 latest items ( 5 centered , like "default eden-confluence" will be enough for me )
thanks ...
Yeah that can be done quite easily...will send you the modified xml in the next days...
mm
Is your TVGuide using tv show next aried script v4.1.3 ?
Afaik, yes...But i can check later on...will report back
thanks ...
mardup, before i start coding is it enough if you copy the "IncludesRecentlyAdded.xml" from standard confluence into the 720p folder of my skin? Would this be sufficient for you?
cheers,
mm
Reason i ask, my mod of confluece, was a dharma version and i am in the process of cathcing up to pre-eden (eden) and with that, updating the scripts associated wit teh skin also, tv show next aired updated their script to work on eden (coupel of version) and the latest version chnages skin tags(syntax- if you will) so running then results in blank screen since thay have changed variable and conditions etc.. and if you have already done so and yours works with 4.1.3 i would like to see how you did it before i jump on it
hey cruzannavy...
just have taken a look...installed is 4.1.3 and it's working...so you might check my xmls to get yours up and running...
If something is not clear, just give me a hit ;-)
cheers,
mm
I know this might be asking alot, but are there any screen shots of all your tv guide screens ( ie home widget if you have one, tv guide itself, daily guide if you have one)?
I know i can always download ur skin and look at it that way but i am curious to see what it looks like before hand..
will make some screenshots...don't know if I will have time to this evening...
mm
mad-max Wrote:mardup, before i start coding is it enough if you copy the "IncludesRecentlyAdded.xml" from standard confluence into the 720p folder of my skin? Would this be sufficient for you?
cheers,
mm
Yes ... But what i would like is with recently added albums ...
Tanks....
Ok...will integrate it for you...
mm
