Full Version: [Help]Weird focus for submenus
Hey Guys...
a few days ago I started to learn skinning with the new horizontal confluence...
I added the option to lower the menubar but there seems to be a problem with it...
I duplicated the group for the menubar in home.xml and have one set to
<visible>Skin.HasSetting(LowerMenu)</visible>
and one for
<visible>!Skin.HasSetting(LowerMenu)</visible>
Funny thing is that the first group is ever alright with submenus, no matter if first "group" is
or
The second group instead seems to have a problem with the "HasFocus" as it does not matter if weather, music or system etc. is selected...it always shows the submenu for videos...
Here is my home.xml---> pastebin
Anyone has a hint for me?
Thanks for the help in advance.
cheers,
mm
You have 2 groups or 2 different xml files ? I think the best way is to keep them separate. Just my opinion ...
mad-max Wrote:Here is my home.xml---> pastebin
had a peek but didn't spot anything obvious at first sight.
but...instead of duplicating the menu code,
why not use a conditional slide animation instead?
Hey butch...
I have 2 different groups as I do not know how to split the options for Skin.HasSetting in two different IncludesXYZ.xml...
cheers
ronie Wrote:had a peek but didn't spot anything obvious at first sight.
Ok so the code seems to be alright...
Why I do not use a conditional slide animation? I guess, I´m not skilled enough for that...
But If someone can help me out this, it would be very much appreciated...
cheers
ok, i guess all you need is this then:
<animation effect="slide" start="0,0" end="0,110" time="0" condition="Skin.HasSetting(LowerMenu)">Conditional</animation>
no need to duplicate ~200 lines of code if only you want to have it a little lower on screen ;-)
Awesome Ronie...you made my day!!!
