2011-06-07, 23:29
I recently maxed out the internal hard drive in my xbmc system, mostly with tv shows. I decided that the easiest solution was to archive older shows and older seasons of some of my current shows to an external hard drive. I would like to still be able to watch these shows from time to time, but don't want to leave the external drive connected and turned on all the time. So I first moved some of my older shows that have been cancelled. I simply moved the entire show directories to the external drive, cleaned the library, and added the external drive as a new source. Xbmc searches for new content, and all my shows pop back into place, but in their new locations. As long as I never clean the library without the external drive connected, I think I'll be fine.
Then I run into problems archiving old seasons of current shows. I have some shows like CSI and CSI:NY that have been around eleven and seven seasons respectively and I just don't need all of those "live". No problem I think, I'll just move the bulk of the old seasons to the external drive and only keep the past season or two on the internal drive. The only problem is, I can't figure out how to get xbmc to merge multiple seasons of the same show from two sources. I went through the same process of cleaning the database, making sure xbmc still sees the external drive as a tv show source, and tried to do get xbmc to grab the old seasons content. No luck at all. Can anyone help me figure out if it's possible to do this, and if it is, where I've gone wrong?
*** External drive ***
External:/CSI.NY/CSI.NY.S01E01.avi
External:/CSI.NY/CSI.NY.S01E23.avi
External:/CSI.NY/CSI.NY.S02E01.avi
External:/CSI.NY/CSI.NY.S02E24.avi
Repeat this pattern for seasons 3-6
*** Internal drive ***
Internal:/CSI.NY/clearart.png
Internal::/CSI.NY/CSI.NY.S07E01.mkv
Internal:/CSI.NY/CSI.NY.S07E22.mkv
Internal:/CSI.NY/fanart.jpg
Internal:/CSI.NY/folder.jpg
Internal:/CSI.NY/logo.png
Internal:/CSI.NY/season01.tbn
Internal:/CSI.NY/season02.tbn
Internal:/CSI.NY/season03.tbn
Internal:/CSI.NY/season04.tbn
Internal:/CSI.NY/season05.tbn
Internal:/CSI.NY/season06.tbn
Internal:/CSI.NY/season07.tbn
Internal:/CSI.NY/tvshow.nfo
I left most of the infrastructure files on the internal drive thinking that it would make more sense for it to always have that information and then only grab the old episodes off the external drive when I connected it up and requested one of those old shows. Am I just trying to make this too complicated? Am I missing something obvious?
