Full Version: IRW works, XBMC doesn't
Hi there, I've got an HA-IR01SV that isn't working.
I've done the device changes and dkmsing and so on and so forth as detailed in other threads. With debug on, xbmc sees the commands coming from the remote, and just doesn't do anything with them:
13:33:21 T:3055449984 M:1811521536   DEBUG: LIRC: Update - NEW at 42329:000000037ff06be9 00 Play vista_mce (Play)
13:33:22 T:3055449984 M:1811521536   DEBUG: LIRC: Update - NEW at 43046:000000037ff06bea 00 Rwd vista_mce (Rwd)
13:33:23 T:3055449984 M:1811558400   DEBUG: LIRC: Update - NEW at 43630:000000037ff06be6 00 Stop vista_mce (Stop)
13:33:23 T:3055449984 M:1811558400   DEBUG: LIRC: Update - NEW at 43947:000000037ff0ebeb 00 Fwd vista_mce (Fwd)
13:33:23 T:3055449984 M:1811525632   DEBUG: LIRC: Update - NEW at 44412:000000037ff06be9 00 Play vista_mce (Play)
13:33:24 T:3055449984 M:1811525632   DEBUG: LIRC: Update - NEW at 44730:000000037ff06be0 00 Down vista_mce (Down)
13:33:24 T:3055449984 M:1811525632   DEBUG: LIRC: Update - NEW at 45162:000000037ff06bde 00 Right vista_mce (Right)
13:33:25 T:3055449984 M:1811537920   DEBUG: LIRC: Update - NEW at 45447:000000037ff0ebe1 00 Up vista_mce (Up)
13:33:25 T:3055449984 M:1811537920   DEBUG: LIRC: Update - NEW at 45730:000000037ff0ebe1 00 Up vista_mce (Up)
13:33:25 T:3055449984 M:1811537920   DEBUG: LIRC: Update - NEW at 46046:000000037ff0ebdf 00 Left vista_mce (Left)
13:33:25 T:3055449984 M:1811570688   DEBUG: LIRC: Update - NEW at 46362:000000037ff06bde 00 Right vista_mce (Right)
13:33:26 T:3055449984 M:1811570688   DEBUG: LIRC: Update - NEW at 46646:000000037ff0ebe1 00 Up vista_mce (Up)
13:33:26 T:3055449984 M:1811570688   DEBUG: LIRC: Update - NEW at 47162:000000037ff0ebef 00 Volup vista_mce (Volup)
13:33:27 T:3055449984 M:1811537920   DEBUG: LIRC: Update - NEW at 47530:000000037ff06bec 00 Chdown vista_mce (Chdown)
13:33:27 T:3055449984 M:1811537920   DEBUG: LIRC: Update - NEW at 47746:000000037ff0ebed 00 Chup vista_mce (Chup)
13:33:27 T:3055449984 M:1811537920   DEBUG: LIRC: Update - NEW at 47863:000000037ff0ebef 00 Volup vista_mce (Volup)
system summary says xbmc 10.1 git:unknown compiled mar 9 2011. aspire revo 3700. what other information can I provide? Any thoughts?
Just last night I figured out Lirc with XBMC here are some of my findings that may affect you.
1) You have to start the lirc service not just run the lircd. Either have it run at boot normally or run "sudo service lirc start"
2) That has to be done before XBMC starts for it to see it. If you are running Live for testing you can stop then start xbmc-live after the lirc service is running or just do that before starting XBMC under a normal Linux distro.
That should be enough
