Full Version: XBMC Live from USB-Boot on AMD Zacate
Hello
my MSI Zacate Board has just arrived, I grabbed an AMD-adapted ISO [1] and put it using unetbootin on an FAT32 Usb-Stick.
XBMC is booting, then it complains in the step "Load installer components from CD" that it is not able to do so...
Any advice?
[1] http://forum.xbmc.org/showpost.php?p=752...tcount=109
I'm sorry I'm replying to such an old thread, but I came across this topic when having the same problem, so I though I'd post the solution here.
Three files in the "\pool\main\l\linux" folder on the usb stick have incorrect naming:
firewire-core-modules-2.6.35-22-generic-di_2.6.35-22.33_amd64.ud
fs-secondary-modules-2.6.35-22-generic-di_2.6.35-22.33_amd64.ude
pcmcia-storage-modules-2.6.35-22-generic-di_2.6.35-22.33_amd64.u
They should read:
firewire-core-modules-2.6.35-22-generic-di_2.6.35-22.33_amd64.udeb
fs-secondary-modules-2.6.35-22-generic-di_2.6.35-22.33_amd64.udeb
pcmcia-storage-modules-2.6.35-22-generic-di_2.6.35-22.33_amd64.udeb
Apparently the filename is truncated to 64 characters. This seems to happen when the USB stick was created on Windows 7
