in this video
Here about the ZOTAC ZBOX Blu-ray AD03,
which is powered by the E350 APU,
we can see at 2min15sec in the video that the guy is running XBMC with AEON skin,,,
i think its AEON MQ2 skin,,,
I was looking for a video like this for awhile
so i could see how fluid AEON MQ2 would be on a Zacate platform,,,
However, judging by the video. looks like what everybody said is true...
It works, its usable, but not super hyper fluid zero delays...
what os was he running ? if it was windows i can test it for you if u want ...
dont think its linux as it doesnt play well with AMD.... :/
He says in the video that it is running windows 7
i got it running fine in linux once ... but failed sabnzbd , couchpotato and sickbeard
but i'm waiting till openelec shows up with theyre ati build
i'll test it tomorrow or so and let u know
aeon nox is running fine btw
So here is another opportunity for me to look like a moron, I might as well take it. The only Aeon skin I see is Nox... where would I find MQ2? Ok, there I did it...
HansP Wrote:i'll test it tomorrow or so and let u know
AEON NOX runs fine because its based of Confluence skin,,,
its the fastest AEON skin version,,,,
You should take into account he's running capture software as well so performance is going to be a little to a lot better than that depending on what he's using and the size he's capturing at
thats true tho >>X<< ... good call ....
well, if someone could do a little Zacate + AEON MQ2 video for us,
we could really see how it performs,,,
preferably while win7 is installed on an SSD
http://www.youtube.com/watch?v=ahU0HfhCo_E
is it this movie ?
i u sponsor me an SSD i should be fine :p
ssd is planned end of this year
like i can see it used a normal 2,5inch hdd 250gig so maybe it works fine with my setup
well i can confirm it runs fine with my normal 5400rpm 2tb Samsung HDD ...
between menu and movies-tv shows takes a second or so but the navigation is smooth !
if someone could shoot a little Zacate + AEON MQ2 video,
we could then judge how it performs using our own eyes,,,
