2011-06-13, 15:43
2011-06-13, 15:43
2011-06-13, 15:44
EDIT 31/08/11: These were included in official release 2.0.5 of CE2, except for the french moviegenres. So if you're french speaking, download the files below
The final new moviegenres in PNG: http://www.mediafire.com/?1oho5h7uiusuqfc
whole sets in french and finally translated in english
Each icon comes in standard but also with "3D" or "HD" overlay
I also made new "watched" and "trailer" overlays, orange virtual keyboard, new "Power" buttons" and some other updates
Cheers!
Download link for "trailer.png" in bigger size, same look but with 150px and 200px width
http://www.mediafire.com/?wj68uj3mhjl3mmp
Cheers!
2011-08-02, 16:03
here is a link to the moviegenres editable sources, in Illustrator CS4 format (10Mb):
http://www.mediafire.com/?l69vc08i5cg0c3o
2011-08-07, 15:08
here are new default icons, whole set.
Just a few samples of them:
Download link:
http://www.mediafire.com/?33rvu8rz8kawygd
I also made the calibration crosses orange instead of blue (included in the archive too)
Download link:
2011-08-07, 15:11
Here is french string for 2.04 & 2.05: http://www.mediafire.com/?usguwbrne4fnm28
EDIT: Here is french string for 2.07:http://www.mediafire.com/?ifkrcvnrvqg4lfm
2011-08-07, 15:13
Here is below my first attempt for the system tabs background. I tried to make the symbols the most minimalist possible, and put them on an abstract background. Every background had its laser line color edited by 10%, so when you'll navigate the tabs, thanks to the fade effect, the line will slightly change from yellow > orange > red > orange > back in yellow
the pictures have to be copied in the "backgrounds" folder of CirrusEx... Please make a safe copy of the original ones so that you can revert them if you dislike my work
Download link:
http://www.mediafire.com/?ze1w0sdgstacokk
Illustrator source files for the symbols + background:
http://www.mediafire.com/?2ug37n5okdkkxtk
Download link:
2011-08-07, 15:15
2nd version of the system backgrounds, with the black box behind the symbols
Personally I prefer this one
Download link (updated)
http://www.mediafire.com/?z9u3qn29kcslka3
2011-08-07, 15:34
EDIT: it was just a dream... after some chats with skilled coders it seems impossible to do (except, maybe, in old XBox setups... mine is getting more and more dusty under the TV for years... I'm too lazy to try on it)
Test for the DefaultFolderBack icon in animated GIF format (the only one that would be animated indeed, as it's the most common one. The other icons should stay stationary)
2011-08-13, 11:01
I don't know if it's a bug or a willing of Butcha, but the volume bar on my setup has always been in the upper right. Or maybe it's because my TV is just HD, not FullHD...
I prefer it centered
For those who would like to change its position, here is the trick (just edit the XXX until you are satisfied):
File:
720p/DialogVolumeBar.xml
<window id="104">
<defaultcontrol>1</defaultcontrol>
<animation effect="slide" start="0,-40" end="0,0" time="100">WindowOpen</animation>
<animation effect="slide" start="0,0" end="0,-40" delay="400" time="100">WindowClose</animation>
<controls>
<control type="group">
<posx>480</posx>
<posy>0</posy>
<control type="image">
<posx>0</posx>
<posy>-10</posy>
<width>300</width>
<height>50</height>
File:
<window id="104">
<controls>
<posx>480</posx>
<posy>0</posy>
<posx>0</posx>
<posy>-10</posy>
<width>300</width>
<height>50</height>
2011-08-13, 11:03
EDIT 31/08/11: included in official release 2.0.5 of CE2
Another thing I keep manually changing on every new release.
it's a little detail, but well, I like corporate things.
Basically it changes the blue color texts in the Weather/WeatherPlus section into the corporate CirrusEx orange.
File:
Colors/defaults.xml
<colors>
<color name="white">FFFFFFFF</color>
<color name="grey">FFb4b4b4</color>
<color name="grey2">88FFFFFF</color>
<color name="grey3">33FFFFFF</color>
<color name="black">FF000000</color>
<color name="blue">FFEB9E17</color>
<color name="selected">FFEB9E17</color>
<color name="dialogheader">DDced8da</color>
<color name="orange">FFB88A00</color>
</colors>
File:
Colors/defaults.xml
<colors>
</colors>
2011-08-17, 21:22
Hey,
Cheers for these edits at least now they are all documented in one easy thread as I was worrying what I'd lose (because i couldnt remember all the edits etc that i had made) when I do the next upgrade
Much appreciated and love the icons and work that you have contributed to this skin.
Keep up the good work and I'll keep an eye on this thread as I love what you've done so far
2011-08-19, 20:52
Just a reminder for myself:
to activate debugging you have to edit addons.xml and set debugging from false to true (©Butchabay)
2011-08-23, 08:05
to make the recently added movies section showing a higher number of items than by default:
Create - in the userdata directory - a blank file named advancedsettings.xml
in this file, paste this code (editing the 500 by the number you want):
This file is independant from XBMC and skins. That means you can change skin and normally even update XBMC, as long as you keep this files in userdata its settings will prevail
<advancedsettings>
<videolibrary>
<recentlyaddeditems>500</recentlyaddeditems>
</videolibrary>
</advancedsettings>
2011-08-27, 00:11
EDIT 19/01/12: compressed orange theme is now included in official 2.0.x releases
Here is the final black&orange theme.
Download Backgrounds and XML files UPDATED 31/08/11
Download a changelog to see what I have changed in XML files
PNG files must be copied in the CE2's media folder, XML files in the 720p folder (please make safe copies of original files first, in case you want to go back to default theme)
EDIT: Butcha seems to have found a way to release it as XBT (XBMC Theme) However, I'm not sure it can handles XML…
"Light Theme" must be disabled in order to have the black & orange home menu visible.
For now this is the manual way, maybe Butcha will include this in a separate theme in future release, maybe playing a bit with the files.
I am not skilled in code. some movies views don't have background, same for some dialog prompts. Maybe Butcha when he'll have more time can add here and there some of these backgrounds to make the whole consistent
I use XBMC only for movies and TV Shows, so I don't have any idea about how my theme looks with music, pictures, games etc
Finally, here are some screenshots:
Cheers
Cheers
2011-08-29, 22:28
