Full Version: set as default for all movies not saving
Having an issue with the latest build, also tried the nightly builds as well.
I did have a search on the forums and found a few issues with nix builds and ios, they were all fairly dated though.
If for example I set the audio track to 2/2 as opposed to 1/2 and then select "set as default for all movies" the settings do not save, when I change to the next episode it defaults back to the first audio track.
each title does save independently though, so if I set it once and go back into that same file it remembers the setting.
Is there a config file or anything I can edit to force the second audio track, I did look in guisettings.xml but could not see anything that would relate to the audio channels.
Thank you in advance
As far as I'm aware that isn't covered by the 'Set as default...' option.
Hitcher Wrote:As far as I'm aware that isn't covered by the 'Set as default...' option.
Hmm ok, is there any way to do it then ? A config file somewhere maybe ?
nobody know if it is possible to achieve this ?
you could always remove the audio line you do not want.
