2011-06-14, 07:12
My only requirements:
1. Must be able to run the Aeon MQ2 skin. I am very partial to this skin.
2. Windows 7
3. Should be able to play blu-ray 1080p mkv backups without stuttering
4. I would like it to be able to run icefilms add-on for viewing 720p Xvid content without stuttering like it currently does on my Apple Tv 2.
5. Able to decode DD 5.1 and DTS is a must, but DTS-HD and TruHD are merely a plus
Other than that, I am not concerned with 3D or WAF. I would like it to be quiet though. Nothing as loud as PS3 or Xbox!
I'll be running XBMC on Windows 7, and I would like fluid movement on the MQ2 skin. Can this be done for sub $300. I can go higher than that, but I would really like <$300 if possible
2. Windows 7
