2011-07-06, 22:10
Guys, been trying to get this working but even though I have NFS shares setup correctly in Lion (same shares as I had previously under Snow Leopard) and other machines can mount these shares without a problem (other Mac's but also a Linux machine) the AppleTV NFS seems to be broken.
Typically I have in a fstab file with a line like this:
This mounts my MacMini Video NFS share to the xxx account on my machine into the Movies/Video folder on my local machine.
I have tried a few combinations via the GUI to get this share enabled on the MacMini with no luck. When I try it via the command line mount command, I get an error that
Looking in /System/Library/Filesystems it only contains hfs.fs for Apple's HFS filesystem. So it seems to me that the required nfs file system code is not part of either the latest offical (which I tried earlier) and the latest nightly from today (which I just tried now). So how are people getting this to work? If so can they share how they did this on their AppleTV.
Also, for those people who got this working where would I mount the video folder locally on the AppleTV so that XBMC can see it. I have a few SMB shares from a different computer shared and working happily on the AppleTV but I cannot see where on the filesystem they are mounted. It must be some XBMC specific share, which might explain why the command line mount doesn't work if people have it working within XBMC. I.e. SMB / NFS code is XBMC specific and doesn't rely on the underlying OS support.
One final thing is someone suggest using showmount -e to diagnose issues, but what commands (other than mount) can I run on the AppleTV as showmount isn't part of the AppleTV build I have. Is it possible to get this via apt-get?
Sorry for the long email, but I would like to get to the bottom of this issue ASAP.
Jerome
MacMini:/Volumes/Video /Users/xxx/Movies/Video nfs ro,user,rsize=32768,readahead=16 0 0
/System/Library/Filesystems/nfs.fs/Contents/Resources/mount_nfs is not found.
Jerome
