Hi ronie
wondering if you could advise of anyway to add the fillmanager as one of my home options. unfortunatley I cant highlight "filmanager" anywhere to add it to my favorites as the only way I can see to get to it is via the shutdown screen. (do you pehaps know what the window ID's and how I could manually alter my homescreen menu, unless of course you know an easier way.
Cheers
RBX
rudeboyx Wrote:Hi ronie
Cheers
RBX
You can add File Manager to the Home menu under Settings
hi jps55 . thanks for the response.
however, i want to add it as a main item rather than in a sub menu as i dont enable the setting option on the home screen. i keep that in the shutdown menu. is there any other way to do this?
rbx
Cheers
RBX
you can manually add it to favourites by editting favourites.xml
<favourite name="FileManager">ActivateWindow(filemanager)</favourite>[HTML][/HTML]
ronie Wrote:you can manually add it to favourites by editting favourites.xml
Great idea, Thanks
Perfect, that will work. thanks ronie.
