Hi all,
I have written a script, which works of course, but when I try to package it for distribution as a zip file, it simply will not install. There is no output to the log, even at debug level.
Is there a published spec for what is required in the zip file, I can't seem to find one.
The zip needs to contain the complete folder of the script.
So:
script.test <- foldername
---->addon.xml
---->addon.py <- or what ever you have in addon.xml for library=
---->changelog <- not necessary but nice to have
---->LICENCE.txt <- also not necessary but needed for the offical repo
---->resourses <- sub folder containing more of your script if needed.
Also, you need to make sure that XBMC has permission to over write the files in the addons folder(sometimes permissions get changed when you manually copy)
giftie Wrote:The zip needs to contain the complete folder of the script.
So:
---->addon.xml
Is it OK to have more stuff in the top level folder, or do they need to be put into resources?
Spent a lot of time poking it, to no avail. Getting log output now, at least... something could be wrong with my addon.xml, but it looks valid to me...
15:32:52 T:3045308272 M:3489304576 DEBUG: ------ Window Deinit (FileBrowser.xml) ------
15:32:52 T:2786036592 M:3489304576 DEBUG: FileManager: copy /home/xbmc/script.subseek.zip->special://home/addons/packages/script.subseek.zip
15:32:52 T:2786036592 M:3489529856 DEBUG: FileManager, processing folder: zip://special%3a%2f%2fhome%2faddons%2fpackages%2fscript%2esubseek%2ezip/script.subseek/
15:32:52 T:2786036592 M:3489529856 DEBUG: -- zip://special%3a%2f%2fhome%2faddons%2fpackages%2fscript%2esubseek%2ezip/script.subseek/addon.xml
15:32:52 T:2786036592 M:3489529856 DEBUG: -- zip://special%3a%2f%2fhome%2faddons%2fpackages%2fscript%2esubseek%2ezip/script.subseek/default.py
15:32:52 T:2786036592 M:3489529856 DEBUG: -- zip://special%3a%2f%2fhome%2faddons%2fpackages%2fscript%2esubseek%2ezip/script.subseek/icon.png
15:32:52 T:2786036592 M:3489529856 DEBUG: FileManager: create folder special://home/addons/script.subseek
15:32:52 T:2786036592 M:3489529856 DEBUG: FileManager: copy zip://special%3a%2f%2fhome%2faddons%2fpackages%2fscript%2esubseek%2ezip/script.subseek/addon.xml->special://home/addons/script.subseek/addon.xml
15:32:52 T:2786036592 M:3489529856 ERROR: Could not read addon description of script.subseek
15:32:52 T:2828008304 M:3489529856 DEBUG: thread start, auto delete: 1
15:32:52 T:2786036592 M:3489529856 DEBUG: FileManager, processing folder: special://home/addons/script.subseek/
15:32:52 T:3045308272 M:3489529856 DEBUG: CGUIMediaWindow::GetDirectory ()
15:32:52 T:3045308272 M:3489529856 DEBUG: ParentPath = []
15:32:52 T:3045308272 M:3489529856 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
15:32:52 T:2877291376 M:3489529856 DEBUG: thread start, auto delete: 0
15:32:52 T:2877291376 M:3489529856 DEBUG: Thread 2877291376 terminating
15:32:58 T:3045308272 M:3488714752 DEBUG: ------ Window Deinit (DialogKaiToast.xml) ------
15:33:22 T:2828008304 M:3487571968 DEBUG: Thread 2828008304 terminating (autodelete)
15:33:22 T:2786036592 M:3487571968 DEBUG: Thread 2786036592 terminating (autodelete)
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<addon id="script.subseek"
name="SubSeek"
version="1.0.0"
provider-name="CSB">
<requires>
<import addon="xbmc.python" version="1.0"/>
</requires>
<extension point="xbmc.python.subtitles"
library="default.py" />
<extension point="xbmc.addon.metadata">
<summary>SubSeek</summary>
<description>Innovative seeking interface for XBMC</description>
<platform>all</platform>
</extension>
</addon>
The lack of logging is an issue... I had some problem and it turned to be the addon.xml
make a new copy of a working addon.xml and only change the bare minimum making sure not introducing any windows line breaks or anything else. To be safe edit it in linux (if feasable)
vikjon0 Wrote:The lack of logging is an issue... I had some problem and it turned to be the addon.xml
I copied the addon.xml from XBMC Subtitles, changing only the "addon id" part, and I get no log output whatsoever now. Awesome.
