Full Version: Calling function from outside
cut things short his the basics of what im doing
Quote:class mainmenu(xbmcgui.window):
# with stuff here and claling the option window
class options(xbmcgui.window):
def printmy(self, txt):
print txt
#draw to window
return
def something (incoming):
#need to call the printmy in option class.
win = mainmenu()
win.domodal()
del win
where it says #need to call the printmy in option class.
i need to be able to call the printmy function in the option class. so i can pass data through.
at the time the somthing function is called the option class is active and visble and running.
any help would be greatly appreicated. thanks in advance
the way you wrote it, def somthing isn't in another class. i assume it is though, and that that is what you intended.
one way of doing it:
     print txt
     #draw to window
     return
class outside:
      self.options = options()
      self.options.printmy("whatever you want to print")
if you didn't mean to put def something in another class, you can simply call it with self.printmy().
there might be wrongs in this explainatin as i am tired, but i hope it helped a bit.
you posted in the wrong forum by the way...
