Full Version: [RELEASE] Xperience More v2.0.3 (Available through the official repo)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20
UPDATE
Fixed the problem in TV Guide when there are more than 6 shows per day. Temp solution until i redo the whole thing.
Check the first post
Cheers
Nessus
Kertis Wrote:little question
is this possible to make shutdown menu in guide? (for example, i dont need to call shutdown menu, i just call guide menu and choosing shutdown panel)
You mean like the original Xperience ?. Yes it can be done but i am not gonna do it in my mod. If you want i can make the change just for you. PM me and i will send you the changed files.
Cheers
Nessus
nessus Wrote:Not yet but soon.
In Includes_Window-Contents.xml on line 541 remove this : | Control.IsVisible(53).
Cheers
Nessus
That worked perfectly for movies an tv. But the Music panel still has the dimmed background. Where should I look?
nessus Wrote:UPDATE
Cheers
Nessus
My buddy, friend, pal, teacher, mentor.... (did I leave something out?)
Since you plan on re-working the TV Guide anyway... how about a "page down" feature to show days when there are more than four shows being recorded/downloaded (on the week view). I know that is a challenging/tough request... just a thought.
thewarm Wrote:That worked perfectly for movies an tv. But the Music panel still has the dimmed background. Where should I look?
In the same line. Remove or add controls ID to remove or add the dimmed background in any window or view. If you want you can remove it from everywhere by deleting all the lines from 535 to 543.
Cheers
Nessus
PS. Buddy, friend, pal... yes. Thanks, glad to know that. Teacher, mentor.... please NO. I am too far away to consider my self anyone's teacher or mentor in XBMC skinning.
nessus Wrote:In the same line. Remove or add controls ID to remove or add the dimmed background in any window or view. If you want you can remove it from everywhere by deleting all the lines from 535 to 543.
Cheers
Nessus
535 takes me to the "scrolling letters" section. What section should I be looking for?
BTW, I got rid of all the other "controls XX" on the same line as the first mod. still have the dimmed background.
Nessus, I created a new thread for the video intro..
Hi
I have read this threed three times I think, but can`t seem to find it.
I have set in the options that it should show watced/not watched, but in Tri Panel View, I don`t see what movies that are watced. And thats something I really miss.
Maybe I doing something wrong, but please help me.
XBMC 10.1,
pettergulbra Wrote:Hi
XBMC 10.1,
You don't see this ?
nessus:
No, I don`t. And I think that is strange.
If you press "W" in keyboard in one movie that you have watched do you see it ?
Suddenly it worked. I Don`t know what I have done. But now it works.
Thank you for the help.
No problem... glad that worked.
Cheers
Nessus
excuse me but is it possible to enable other view in program section ( for advanced launcher)?
my problem is that pc cover aren't square shaped but rather poster like so when I view my game the cover appear all deformed....Sad
I have the same problem for other emulator.I did find someone who did this but his link to his mod is dead so....if you could explain to me how I can do that it would be great!!
because this is the only thing that prevent me for using your skin that is really great otherwise!!
anyway thanks again for your work!!
Follow the instructions in this thread to enable the view that you want in programs section. If you stack somewhere let me know and i will do my best to help you.
Cheers
Nessus
