Full Version: [RELEASE] Xperience More v2.0.3 (Available through the official repo)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20
Nessus your doing me prowed Nod nice update, I'm loving the dark look.
I also like the dialogs. I think there are still people who like your mod more as it's closer to the original Xperience and has different views than my skin. So keep it up. Smile
Thanks Rocky. I really appreciate it.
Black... thanks men. Of course i don't have your excellent graphics skills but i do my best.
can't wait...arg...when do you intend to release it!?
bakito Wrote:can't wait...arg...when do you intend to release it!?
Next update is coming up after Eden final release.
Cheers
Nessus
ok!
I'll command some patience to santa!
thanks!
cheers
dear Friend
I install with success the Nessus's file.
How to mod picture in program panel for this result http://imageshack.us/photo/my-images/411/qzdqu.png/
you have the update on the first page.
the "poster view" for programm
check the first post!
cheers
Could you be more explicit please?
I had download the upgrade in the first page and adapt it for my xbox with Ysirius instruction http://forum.xbmc.org/showthread.php?tid=70165.
i install it with success, but the poster apparence work but I don't know change the default image by front box game pdf file for example.
Could you be more explicit, please? I download update and I install it with success with Ysirius's instruction for XboX. The poster works in program, but I don't know how to change the default image by a front box covert pdf file for example, like show in the link.
go there and take the file for the program viewSmile
https://docs.google.com/#folders/0B4zn-B...c1NDZhZTc2
thanks to nessus!!
cheers
bakito Wrote:go there and take the file for the program viewSmile
thanks to nessus!!
cheers
...or wait for the next major update of the skin.
yes! héhé
Dear
One solution:
-go to /E/APPS/XBMC/UserData/Thumbnails/Programs and erase all folders
-re create all folders (0,...,9,a,..f)
-in Viewtype_File Panel change all occurrence of default.png by default.tbn
-same thing for .png to .tbn
-In game's folders where appear default.xbe, export your covert
-at last change the name of your picture by default.tbn
Beware, the folder in Thumbnails/Programs (for exemple/E/APPS/XBMC/UserData/Thumbnails/Programs/0) doesn't must be contain a default covert, you must erase it, after export your covert. Else this is the fisrt picture appears on poster.
Dear Friends
Almost there:
I need to raise all poster of some centimeter, for do appear option icon, and erase the label in the top.
Could you help me please
