2011-06-20, 10:47
Hi.
I installed in usb key Live(freak) version and added a 3TB HD GPT NTFS formatted.
After installed nfs and writing:
sudo fdisk -l
the report is this:
WARNING: GPT (GUID Partition Table) detected on '/dev/sda'! The util fdisk doesn 't support GPT. Use GNU Parted.
Disk /dev/sda: 3000.6 GB, 3000592982016 bytes
121 heads, 34 sectors/track, 1424534 cylinders
Units = cylinders of 4114 * 512 = 2106368 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk identifier: 0x1b152fab
Device Boot Start End Blocks Id System
/dev/sda1 1 1043988 2147482623 ee GPT
Partition 1 does not start on physical sector boundary.
Disk /dev/sdb: 4009 MB, 4009754624 bytes
124 heads, 62 sectors/track, 1018 cylinders
Units = cylinders of 7688 * 512 = 3936256 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x000e9648
/dev/sdb1 * 1 960 3685376 83 Linux
Partition 1 has different physical/logical beginnings (non-Linux?):
phys=(0, 32, 33) logical=(0, 33, 3)
Partition 1 has different physical/logical endings:
phys=(458, 238, 36) logical=(959, 0, 8)
Partition 1 does not end on cylinder boundary.
/dev/sdb2 960 1019 227329 5 Extended
Partition 2 has different physical/logical beginnings (non-Linux?):
phys=(459, 16, 4) logical=(959, 33, 9)
Partition 2 has different physical/logical endings:
phys=(487, 92, 53) logical=(1018, 50, 20)
Partition 2 does not end on cylinder boundary.
/dev/sdb5 960 1019 227328 82 Linux swap / Solaris
So GPT is NOT supported.
How to solve?
sudo fdisk -l
the report is this:
How to solve?
