Full Version: [LIRC] don't work - trust rc-2400
Hi.
Lirc does not work for me Blush
I tried everything. Sad
I am running Trust IR Receiver + Trust RC-2400
It looks like LIRC does not get event from receiver.
Quote:[ 161.573342] usb 3-2: new low speed USB device number 3 using uhci_hcd
[ 161.760708] Registered IR keymap rc-rc6-mce
[ 161.760858] input: Media Center Ed. eHome Infrared Remote Transceiver (147a:e017) as /devices/pci0000:00/0000:00:1d.1/usb3/3-2/3-2:1.0/rc/rc1/input8
[ 161.760948] rc1: Media Center Ed. eHome Infrared Remote Transceiver (147a:e017) as /devices/pci0000:00/0000:00:1d.1/usb3/3-2/3-2:1.0/rc/rc1
[ 161.761170] rc rc1: lirc_dev: driver ir-lirc-codec (mceusb) registered at minor = 0
[ 161.761191] mceusb 3-2:1.0: Registered Formosa21 SnowflakeEmulation on usb3:3
Quote:Bus 003 Device 003: ID 147a:e017 Formosa Industrial Computing, Inc. eHome Infrared Receiver
What to do?
Do you get any response when you run irw in the command line?
Have you set lirc up to use devinput? Looks like it should workfine.
dashford Wrote:Do you get any response when you run irw in the command line?
no
darkscout Wrote:Have you set lirc up to use devinput? Looks like it should workfine.
Quote:#Parameters for daemon
LIRC_DEVICE="/dev/input/by-id/usb-Formosa21_SnowflakeEmulation_C0014E23-event-if00"
LIRC_DRIVER="devinput"
LIRC_EXTRAOPS=""
LIRC_CONFIGFILE="/etc/lirc/lircd.conf"
This is my config
Quote:[root@myhost piotrek]# cat /dev/input/by-id/usb-Formosa21_SnowflakeEmulation_C0014E23-event-if00
When I press buttons, nothing happens
What about ir-keytable? What does it show?
Quote:[root@myhost piotrek]# ir-keytable
Found /sys/class/rc/rc0/ (/dev/input/event4) with:
Driver mceusb, table rc-rc6-mce
Supported protocols: NEC RC-5 RC-6 JVC SONY LIRC
Enabled protocols: RC-6
Repeat delay = 500 ms, repeat period = 125 ms
that's it
irrecord does not see any events
any help Sad?
ir-keytable -t
Press buttons.
