Full Version: Video start lagging after a while.
So this is my setup:
I have a computer with a core 2 quad q9550
and 6ghz of ddr2 pc8500 (1066mhz) of ram.
Graphic card is nvidia geforce GTX260 GS (Gold Sample)
(windows 7)
Im running the digital video signal by hdmi from the graphic card to the reciver, then by hdmi from my reciver to my TV (LG LE850n).
The sound im running from my computer to the reciever by optical.
It recognices the TV as LG TV, Generic PnP Monitor.
The settings for the TV on the computer is set to 60Hz 32bit true color.
The settings in xbmc is:
Video Settings -> Playback
Render Method: Auto Detect
Allow hardware acceleration (DXVA2): off (no difference with this on)
Adjust display refresh rate to match video: off (with this on, it laggs alot)
Sync playback to display: off (I dont know what this does, always been off)
Allowed error in aspect ratio to minimize black bars: none
Display 4:3 videos as: normal
video post-processing: disable (tried always eneblad, no diffrence)
So whats happening is:
I start a movie, it runns perfectly smooth. After aprox 15mins it starts to lagg, not very much tho. Sound dosnt lagg at all it still runs smooth. If I pause the video for a few seconds and resumes it, the lagg is gone. But after 15min of watching it happends again. Its like this over and over again.
Iv had task manager up on my 2nd monitor, and cpu or memory useage is max at 40% each.
Any ideas?
If you need more information or want me to try somthing tell me =)!
anyone ? This issue is annoying me pretty much ;S
No idea. BUt you will want to start by positing a debug log of when this happens. Turn on debugging (settings | System | Debugging) play the media until you experience bad lag. Copy the debug log to pastebin or similar and post the link here. log file is located in %appdata%/xbmc/xbmc.log
