2011-06-22, 09:44
Even in OSX the AppleTv plays the same file fine but in Ubuntu with same Dharma 10.1 it stays at 30 fps flat with CPU at 50% so can't be that I cannot make it
Mediainfo attached
Video
ID :
Format :
AVC
Format/Info :
Advanced Video Codec
Format profile :
[email protected]
Format settings, CABAC :
Yes
Format settings, ReFrames :
4 frames
Codec ID :
avc1
Codec ID/Info :
Advanced Video Coding
Duration :
1mn 55s
Bit rate mode :
Variable
Bit rate :
3 983 Kbps
Width :
960 pixels
Height :
544 pixels
Display aspect ratio :
16:9
Original display aspect ratio :
16:9
Frame rate mode :
Variable
Frame rate :
59.940 fps
Minimum frame rate :
59.920 fps
Maximum frame rate :
59.960 fps
Color space :
YUV
Chroma subsampling :
4:2:0
Bit depth :
8 bits
Scan type :
Progressive
Bits/(Pixel*Frame) :
0.127
Stream size :
54.9 MiB (96%)
Writing library :
x264 core 112
Encoding settings :
cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=600 / keyint_min=59 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=23.0 / qcomp=0.60 / qpmin=3 / qpmax=51 / qpstep=4 / vbv_maxrate=9500 / vbv_bufsize=9500 / crf_max=0.0 / ip_ratio=1.40 / aq=1:1.00 / nal_hrd=none
Encoded date :
UTC 2011-06-20 22:41:22
Tagged date :
UTC 2011-06-20 22:47:26
Color primaries :
BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics :
BT.709-5, BT.1361
Matrix coefficients :
BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Mediainfo attached
Video
ID :
Format :
AVC
Format/Info :
Format profile :
[email protected]
Yes
4 frames
Codec ID :
avc1
Codec ID/Info :
Duration :
1mn 55s
Bit rate mode :
Variable
Bit rate :
3 983 Kbps
Width :
960 pixels
Height :
544 pixels
16:9
16:9
Frame rate mode :
Variable
Frame rate :
59.940 fps
59.920 fps
59.960 fps
Color space :
YUV
4:2:0
Bit depth :
8 bits
Scan type :
Progressive
0.127
Stream size :
54.9 MiB (96%)
Writing library :
x264 core 112
Encoding settings :
Encoded date :
Tagged date :
Color primaries :
BT.709-5, BT.1361
