I'm using the latest nightly build at my ATV2. The log in screen/profile screen in Confluence shows when starting XBMC. But how can I log out from a profile to reach the same screen again?
All I find is the red exit button.
The problem is the iOS guys have forced opening up the shutdown dialog to exit so no log off for iOS until they change that
Jezz_X Wrote:The problem is the iOS guys have forced opening up the shutdown dialog to exit so no log off for iOS until they change that
Ok. I notice that when I hold the menu button in home it also exits. Would it be possible to change so that holding the menu button means opening profiles instead?
Not from my end but keymap change might do it for you
Jezz_X Wrote:Not from my end but keymap change might do it for you
Would it be possible to add Log Out in the main menu? I noticed that you put back Movies and TV.
Sure its possible but I'm not going to do it just for iOS when the proper fix is to make iOS work like every other platform and fix it
