Full Version: Some German translation for a better fit
@stoli
I changed the strings.xml a bit. Hope you don't mind. If you find my work is good enough feel free to use it.
If you want to use it, just change the strings.xml under xbmc\addons\skin.neon\language\German with mine. I haven't changed everything cause a lot is skin related and i didn't want to change too much of stoli's work.
You can get it here http://netload.in/dateikE1dIhgW0b/strings.xml.htm Sorry for that, but I can't attach something - why is that?
Image Image
Image Image
scorpie
Thanks - I'll be sure to include these in the next update.
