Full Version: Intermittent navigation sounds
Not sure which forum this really belongs in but I'll try here.
By testing out the AudioEngine builds I have navigation sounds working again on the ATV. And with this I'm back with the same problem with one of my receivers that I had back with XBMC on the XBox as well:
When I chose digital out (Optical/coax), the navigation sounds only show up if I rapidly navigate through the UI. The *first* click doesn't make it through. It's like the receiver goes to sleep whenever there's more than one second pause, and then it needs a signal to wake up again.
This only happens on my 9 year old Sony receiver which only has Optical inputs (no HDMI).
On the XBox, I was able to get around this problem by choosing "Output stereo to all speaker" but that no longer seems to be an option in ATV ?
Is there some sort of "keepalive" that XBMC could send which would mitigate this problem ?
Navigation sounds are not enabled in ios/atv2. There is no SDL mixer present in trunk code.
The only branch where you might find navigation sounds are under the AudioEngine test builds.
Let's please be specific about statements so others don't get confused.
Sorry, original post updated to be less misleading.
