Full Version: [Nightlies]Is there a way to reset a broken app
Couple builds ago everything was mark as broken, or atleast I clicked yes so the 'pop-up' would go away. Now I cant seem to be able to reset all my addons to working?
You could try to delete the addons files from \XBMC\userdata\addon_data
I did this to fix my tv.show.next.aired addon when it wasn't working. Then restart XBMC and it will go back to default settings.
What you do is select the xbmc repo and force refresh on context menu, all addons will be restored... except for the ones which are truly broken (around a hand full)
