After i update to 10.0-9 i cant play music in xbmc over smb. it freeze 1 sec in the sound and somtime it freeze the atv2 so i have to unplug the power to restart...
plz help
kredemanden Wrote:After i update to 10.0-9 i cant play music in xbmc over smb. it freeze 1 sec in the sound and somtime it freeze the atv2 so i have to unplug the power to restart...
plz help
can i get the 10.0.09 xbmc download address from you?
thanks
fabulous Wrote:can i get the 10.0.09 xbmc download address from you?
thanks
http://forum.xbmc.org/showthread.php?p=8...post824476
The actual .deb file (if you want it) is behind the link on the first line of that post. If you just want to install, then follow one of the set of instructions that are also in that post
procrastinator Wrote:http://forum.xbmc.org/showthread.php?p=8...post824476
thanks you for your reply
