2011-06-27, 20:02
Is there a way to sort the channel list via the UI? Or are there any files which I can edit to sort it manually?
Also it seems that adding channels to a user defined channel group are not saved correctly. Maybe it's a my fault? If it's not, I will try to nail the problem down.
Chris
Chris
