2011-06-29, 14:54
OK basically I have a lot of movies and have been using xbmc for a LONG time (back on my Xbox which I loved). I have a few questions for the community.
First, what is the best way to store DVD rips? Should I use ISO or Video_TS folders? Are there pros/cons to each option?
Second, what is the best folder structure? I see three folder structures:
1. Would be separating them by type:
//Movie/HD/movie1 (year).mkv
//Movie/DVD/movie2 (year).iso
//Movie/movie3 (year).avi
2. Would be putting each movie into a separate movie folder:
//Movie/HD/movie1 (year)/movie1 (year).mkv
//Movie/DVD/movie2 (year)/movie2 (year).iso
//Movie/movie3 (year)/movie3 (year).avi
3. Would be all movies in one folder:
//Movie/movie1 (year).mkv
//Movie/movie2 (year).iso
It would be great to see the pros and cons to each one of these options.
I will start with some pros and cons to the folder structures:
1.
Pros:
Skins that review naming will find the HD and the DVD where required.
Ability to scan for new movies on sub folders which will run quicker
2.
Pros:
Ability to use extra fanart on skins that have that ability.
3.
Pros:
Easy of use. Simple single place to put the files
Cons:
Longer to scan.
If anyone can give a better picture of the pros and cons to the two questions above I would appreciate it.
Thanks in advance.
Regards,
SoBBie
1.
Pros:
2.
Pros:
3.
Pros:
Cons:
Longer to scan.
Thanks in advance.
Regards,
SoBBie
