Full Version: XBMC Constellation For iPad/iPhone by FSS.cc (unofficial remote)
(2012-04-04, 12:22)FSS_Dawid Wrote: [ -> ]
(2012-04-04, 00:02)NaDs Wrote: [ -> ]how does one become a beta tester??
i have a pvr version of xbmc so i could help with that
sure send me an email to support
i have sent you a pm - thanks Smile
(2012-04-04, 12:58)NaDs Wrote: [ -> ]
As have I Smile
Quote:@all random users having thumbnail issues:
This 'may' not be the cause, but it's been determined that if you have any special characters (!, ^, &, etc.) in your username or password for XBMC it can cause issues with getting the thumbnails. So if that's the case for you, please try to change that info, flush your image cache and re-sync to see if it solves the problem.
fixed it for me....Thanks!!!
Hi I use to use this on my iPad 2 just fine, but with the recent updates and on my new iPad it seems like everything is very choppy and sluggish when going into the TV Show and Movie section. The home section is very smooth. Its just those other two areas.
Hi there,
Recently bought the universal version for my iPad - love it! Right now I"m missing channel icons - I use For the Record on the back end.
On the Constellation forums I found a user with the same issue, he sent you guys his files and the thread mentions you'd get back to him. Was this issue ever resolved, or did you figure out what For the Record users need to do?
The thread in question is here: http://constellation.ictcsc.net/index.php?topic=50.0
Thanks! And I'm more than happy to beta test this or other fixes, if you need testers, just let me know.
Noticed that the Season and Episode Numbers are doubled
fss.
        Please implement special characters in the constellation as the names of movies in my language are so bad ....
My language has accents
My language is Portuguese-br
(2012-04-04, 19:28)mobious Wrote: [ -> ]Hi I use to use this on my iPad 2 just fine, but with the recent updates and on my new iPad it seems like everything is very choppy and sluggish when going into the TV Show and Movie section. The home section is very smooth. Its just those other two areas.
This is the issue I just commented on a few posts above yours. It has been fixed in version 2.2 when that becomes available to the public.
(2012-04-05, 00:53)isamu.dragon Wrote: [ -> ]Noticed that the Season and Episode Numbers are doubled
Is it only for that show or all shows? I've never noticed it. Can you give more details... do you have NFO files for the episodes or do you use XBMC's internal scraper (and which one)?
(2012-04-05, 03:30)iorifly Wrote: [ -> ]fss.
I'm not sure, but I think the special character issue is mainly with username/password. I have some movies that use special characters in them and in Constellation it just displays them as normal characters... (ex. Niña shows up as Nina) Can you PM me a list of some of the movies giving you trouble (and possibly a zip file with corresponding NFO files).
(2012-04-04, 21:35)ixian Wrote: [ -> ]Hi there,
This is fixed in 2.1.3 the current appstore release. Do you have channel thumbnails in XBMC ?
hmmm theres only one thing that can cause this do you use MySql on windows ?
(2012-04-05, 09:12)FSS_Dawid Wrote: [ -> ]
I face the same issue. Windows 7 German, xbmc on sqlite. No problem on XBMC / XWMM.
Uploaded with ImageShack.us
Thanks for your support.
G.
O_o
What scraper are you using ?
Oh, just throwing this out there... for users that said they had some issues with creating custom commands in Constellation... Pending on what skin you use in XBMC you may not see the options (switch to Confluence if you don't) go into "System" -> "Settings" -> "Input Devices" and turn on "Remote control sends keyboard presses" and that should allow commands like the \ key or anything else.
(2012-04-05, 09:42)FSS_Dawid Wrote: [ -> ]O_o
OFDB version 1.1.2.
(2012-04-05, 10:43)Archigos Wrote: [ -> ]Oh, just throwing this out there... for users that said they had some issues with creating custom commands in Constellation... Pending on what skin you use in XBMC you may not see the options (switch to Confluence if you don't) go into "System" -> "Settings" -> "Input Devices" and turn on "Remote control sends keyboard presses" and that should allow commands like the \ key or anything else.
I'm trying this rather unsuccessfully, though. Probably super easy, but, how do I remove a custom command?
I am using windows 7 and use the scraper standard for movies!
