Reece08 Wrote:I requested this download from the app store a couple of days ago, but it wouldn't install because I hadn't updated my iPad in a while. So today I updated to 4.3.3
I was a bit upset, I updated my ipad today, lost all my data, went to the app store and the app was no longer there... Then 5 minutes later the app had automatically installed itself. I was a bit confused, but happy now.
I must have queued the download before you pulled the last version from the app store and it installed itself when it was updated. But, with that said, I'm quiet happy to have this fantastic app, you should be happy I was willing to sacrifice all my data including an order and chaos character I had been leveling for the last few weeks. ALL FOR YOUR APP.
It's awesome, best xbmc control I've ever used, and I'm not having any troubles with it.
Hasn't crashed once.
Used and purchased within 2 minutes of use.
Great job, you totally deserve my money, I don't buy many apps, unless I feel the developer deserves it, and you sir, do.
Sorry for the long post, just wanted to reenforce my love for this app.
Cheers,
Reece
Thank you for your kind words
we really appreciate it!!!!
Yes we took the app down for a couple of days we made a big bug witch didn't come up in the dev releases... So when we downloaded the app store one and it crashed we contacted apple to remove the app from sale immediately. The Fixed version is on a ultra priority review we expect it to be on app store on monday/tuesday. Sorry for all the problems. The proper version is 1.3.1 the one with the BIG bug is 1.3.
we actually are testing v1.4 witch will contain some more useful features
so stay tuned and I hope you will like v1.3.1. The change-log for it:
- Fixed the startup crash
- Internet Radio support iPad/ iPhone
- Redesigning iPhone/iPod version
- Movie set support in XBMC v11 (nightly builds)
- Fixed white screen popping up from admob ads.
- Fixed the last issue with the library sync (long file paths)
- Fixed a infinite loop while pressing the remote buttons....
- Improved memory Management
- added a yellow status indicator
- Improved the gesture zone
- Reorder items in playlists (video/audio) in XBMC v11
- Fixed a bug in tv shows (The "Special" one)
- Fixed UI bug in TV SHows
- Host config can now use *.local/info domains
- Ignoring the "The" in sorting (iPad)
Regards!
