moshelog Wrote:FSS_Dawid
ive just downloaded and installed it
The library doesnt work for me not in xbmc v10 and not in any beta builds .
any eta when the fix is going to released?
thx in advance
moshelog
Send me your device UUID i will send you a dev version wich should resolve this problem.
Archigos Wrote:I installed it early this morning (like 4ish hours ago) and it showed the correct number of albums but the TV and Movies had the wrong count and pretty much anything I tried to do would cause the app to outright freeze so I had to force quit and when I reopened it, it'd just do the same thing... I've been able to play for a couple minutes at a time and really like some of the views and other things, just not sure why it's crashing like this.
Specs:
64GB iPad (1st Gen) Wifi Only Model running 4.3.3
XBMC running on Windows 7 Ultimate x64
222 Albums in Music Library
500+ Movies and 240+ TV Shows (over 10,000 Episodes)
Any ideas?
meh1965 Wrote:I have a Mac Mini running XBMC.
It's the same problem we made a big bug
It has been resolved and submitted to appstore today You can send me your UUID by PM give
Regards
do i need jailbreak ipad to install the dev version ?
i have ipad2 non jailbreak .
moshelog Wrote:do i need jailbreak ipad to install the dev version ?
Nope, no jailbreak required.... I've used Dev versions of multiple apps (each sent to me LEGIT before someone says something stupid)
awesome app! though one bug on apple tv1 (with crystalubuntu) is that none of the player controls (Video OSD) work. Seems to be only happening on appletv1, works fine with macos.
Got xbmc commander as well, that app doesnt have this problem, I think he had to implement a specific fix just for apple tv.
Let me know if u need more info
Cheers!
Update: had to update to June version of crystalubuntu and it fixed the issue
Hi! Can you please add support for Boxee Box? Please-please-please! =)
Ilia
The support for ATV1 is there just go to your host settings where you can type your ip address and disable event server.
noem
Yes, we plan to add that feature. But first we need a rock-solid release of what we have now after that milestone we will start coding new features. Just remember: this is only the beginning
Or, how Mr. Jobs says, "This changes everything"
haired
Hmmm we'll see
P.S.
we will send dev version in approx. 1 hour
Still have the same problem here.
I might be retarted, but where do i find the gesture controls?
still same problem libary view doesnt work here
In the screenshot, there are mediaflags and a actor listing...i do not see that option with the program. Is there a modification for this? Or am i missing something in an option setting?
lindop this is the libary view movies and music but it doesnt work well .
there is abug
Hudson_Hawk04 Wrote:I might be retarted, but where do i find the gesture controls?
Remote --> settings -->Gestures zone --> ON
LindoP Wrote:In the screenshot, there are mediaflags and a actor listing...i do not see that option with the program. Is there a modification for this? Or am i missing something in an option setting?
XBMC v10 dose only server the movie studio all the rest of the "mediaflags" are available in XBMC nightly builds...
moshelog Wrote:lindop this is the libary view movies and music but it doesnt work well .
there is abug
Well we will have to run some tests. I will get back to you.
