m0v1em4n Wrote:I did support them with my purchase, but it would seem that without you answering our question, there would be not technical support, where as the support gone?
Granted I can't say for sure since I don't know Dawid and the others, but it was mentioned at least once prior that they are a small group and they are/were currently working on at least three different applications at the same time. It wasn't stated if all of these were XBMC related, but either way, sometimes priorities may conflict with an end users perception.
I can't think of a good way to word what I'm thinking, but essentially Constellation is a free application that they are spending a lot of their time on. Yes there's a pro version, but when you boil it down, it's the equivalent of a donation button.
Quote:There seem to be a few people having trouble with the nightly builds, me included, I have posted on here and sent e-mail to no avail, They state on Itunes that v11 is " Fully supported" but this is not true because if you go above a certain build thing stop working, perhaps they should state this.
I agree, it probably should be reworded on iTunes, but at the time it was originally written, it was valid. The Nightlies are beta versions and Team XBMC are making constant changes, it's not feasible that any third party app will be "Fully Supported" throughout the entire process of Eden.
Quote:come on FSS guys what happening, perhaps its time to fix to a particular nightly build and tell us all not to go above that.
From what I've been reading, the latest nightly that hasn't had any problems was PRIOR to the Sept. 5 Nightly... For reference, I just checked and I'm currently running the Aug. 29 build with no issues.
Quote:Just so you know what my problems are:
problem 1) When I sort my movies by " Label " My movie collection disappears , But is ok if I sort by Year,Rating,Recently and playcount.
Problem 2) I added some movie sets but they don't show up unless I select sort by Label, and If I do a search only individual movies show not the collection ( perhaps the last bit is by design)
Problem 3) when I select a movie set there is nothing there, no fan art or anything, just black. even though everything show up OK in XBMC
Can someone tell me which XBMC nightly version they are using where they can get there movie collection to show when sorted by label and are you having any problem with sets in that nightly build.
I am presuming that I can install an old nightly version over a recent one
As stated above, I'm using the Aug. 29 build of XBMC and I'm using the 1.4.2 version of Constellation on both an iPhone 4 32GB (4.2.6) and a 1st Gen iPad 64GB Wifi (4.3.3).
For problem 1, I can't reproduce your exact issue since my library shows up fine when sorted by "Label", however, I did notice that if I sort by anything OTHER than "Label" that it displays ALL movies (flattens sets) where "Label" shows the sets correctly. Suggestions:
- Clean Video Library
- Check for Foreign Characters in Titles
Problem 2: This is possibly related to problem 1. When I sorted by "Label" and did a search for a movie I knew was in a set it did NOT show the movie unless it was inside a set with similar name (Ex: Set Name: Harry Potter - you could find it searching that name, but searching the word "Prisoner" for example wouldn't show HP3). When I sorted by "Year" sets didn't show up, so the movie search would find the exact movie but would be blank for set names like "Foreign".
Problem 3: Again, has to be related to Problem 1.
As far as 'downgrading' the Nightly builds... I'm not sure if it works, by the sounds they have made changes to JSON and other areas recently, but not to the database structure itself, so backup your entire userdata folder to another location, downgrade and try it... if you lose your library, reinstall the nightly you were on and after upgrade restore your userdata folder.
