Full Version: XBMC Constellation For iPad/iPhone by FSS.cc (unofficial remote)
I just downloaded it. I can see the movies and libraries, but I can't see movie thumbnails. In my HTPC all movies are showing thumbnails, but when I try to use Constellation, I can't see the thumbnails on it.
I'm using XBMC v10 on a Windows 7 x64 machine. I'm trying to use the Constellation in a 64 GB Wi-Fi iPad. So, I would appreciate if anyone could help me on this.
Thanks in advance!
viellieb Wrote:https://www.sugarsync.com/pf/D787967_977283_8888846
Form the code pont of view this can only happen if you don't have fanart fot the TV Show in XBMC. It's when you are in the XBMC gui do you see fanarts ? What scraper do you use for TV Shows ?
jguilhermemv Wrote:I just downloaded it. I can see the movies and libraries, but I can't see movie thumbnails. In my HTPC all movies are showing thumbnails, but when I try to use Constellation, I can't see the thumbnails on it.
Thanks in advance!
XBMC v10 ?? or V10.1 ?
Can you try eden? http://mirrors.xbmc.org/nightlies/
Regards
Quaith Wrote:I just tried out the recording feature, and it doesn't work for me. Nothing happens when i press the Record button. Adding recordings does work when doing it through XBMC. Can't figure out in the logs what is going on.
XBMC.log: http://pastebin.com/4wEGHHpi
Is this something you are aware of?
Nop I'm just looking @ your log
EDIT:
well:
14:21:59 T:140332191262464   DEBUG: JSONRPC: Calling pvr.schedulerecording
14:21:59 T:140332191262464   DEBUG: JSONRPC: schedule recording - channel: 'Nederland 1 HD' start: '21-12-2011 14:45' end: '21-12-2011 15:00'
14:21:59 T:140332191262464   DEBUG: JSONRPC: recording scheduled
It looks like the the recording got lost in tvheadend... are you sure it isn't scheduled in TVheadend ?
EDIT2
I also noticed that sometimes the recording does not get scheduled if you are playing live TV. Try it without live TV playback
FSS_Dawid Wrote:Nop I'm just looking @ your log
EDIT:
well:
EDIT2
Made sure nothing was playing this time. Still the same issue.
http://tinypaste.com/9862b21f
http://i.imgur.com/PQF7P.jpg
I'm using the git version of tvheadend (compiled about 15 days ago): https://github.com/andoma/tvheadend
Should I be using the opdenkamp version of tvheadend?
Quaith Wrote:Made sure nothing was playing this time. Still the same issue.
No I'm using the git one also.
Is this happening on all channels ?
Do you get a notification on your XBMC ?
FSS_Dawid Wrote:No I'm using the git one also.
Just tried about 30 channels, nothing happening. Also no notifications.
-edit-
I have 3 xbmc installations on windows, mac and linux running in my house and this behavior is the same for all of them
You can try one thing.
1) close XBMC
2) enter the ~/.xbmc/UserData/Databases folder
3) remove EPG#.DB and TV##.db
4) start XBMC
5) w8 for XBMC to sync the PVR data (channels/epg)
6) resync the data in constellation (pull down the channel list)
FSS_Dawid Wrote:You can try one thing.
1) close XBMC
4) start XBMC
Did that, nothing changed..
If this doesn't help I will try to look in xbmc what can be wrong as this is not a problem in constellation but in xbmc. Did you compile XBMC by your self? or you use prebuild versions
FSS_Dawid Wrote:If this doesn't help I will try to look in xbmc what can be wrong as this is not a problem in constellation but in xbmc. Did you compile XBMC by your self? or you use prebuild versions
It is compiled by myself, but through the AUR https://wiki.archlinux.org/index.php/Arc...Repository
It basicly pulls the latest git version and installs all the requirements.
The package i'm getting it from: http://aur.archlinux.org/packages.php?ID=50894
If you want me to compile it by hand I can also do that.
-edit-
The OS X and Windows 7 computers uses a prebuild version.
Quaith Wrote:It is compiled by myself, but through the AUR https://wiki.archlinux.org/index.php/Arc...Repository
-edit-
OK I will make some "log traps" in XBMC and give you the address of the repo later today or tomorrow. Have to finally drive home :? from work.
This is very strange. Can you send me via PM your TVxx.DB and EPG.db? I will have a look @ the data in it.
ok not necessary found the problem in XBMC OpdenKamp did some refactoring Big Grin
I will post a fix today as A PR to the github it's a problem in xbmc
FSS_Dawid Wrote:ok not necessary found the problem in XBMC OpdenKamp did some refactoring Big Grin
Thanks for the amazingly fast support!
i love this app for ios!
but i found a little bug.. when i go under shutdown change user with the pad of constellation my xbmc (openelec) freeze and i must shutdown it with pwr button
