I would like to suggest a couple of improvements to this incredible app, that I bought after 5minutes of usage:
1) a "Restart XBMC" option in the server commands (where you have WOL, reboot, shutdown, etc.
2) multitouch commands in the touch area so that, for example, when browsing your movie list, swiping with two fingers you go down one page.
3) repeat commands in the touch area, useful when you browse a long list of movies (for example, after swiping down your finger, if you keep it steady, it will repeat your 'down' command until you release your finger)
4) quick button to cycle among the audio tracks (like the one for cycling subtitles)
FSS_Dawid Wrote:Form the code pont of view this can only happen if you don't have fanart fot the TV Show in XBMC. It's when you are in the XBMC gui do you see fanarts ? What scraper do you use for TV Shows ?
Fanart in XBMC (11.0 nightly build from around 10th dec. on ATV 2) works fine.
I scraped everything usinger Ember, saving thumbs and nfos on the harddrive, added in XBMC.
Yesterday I refreshed my Constellation-library. Now almost all the tv shows are there (incl. fanart and nfo), and some shows as well. But not all of them. Not sure, but it seems the the shows I opened while connected via wifi are saved completely.
Hello,
I recently updated this awesome app for my iPad, but now I am having trouble, it doesn't matter what I do, the application goes black as soon as I start it, I tried reinstalling it, after fresh install I can use the application, but as soon as I put my host on it, the app freezes and never get back to working.
Any tips. I was about to buy it lol
Ty
Alf
Hi I love the app but I have a question about the manage functions. None of the mange functions seem to work for me. I'm running a pre Eden build of December 11 410C947
Update library's as well as shutdown, reboots etc.
Quaith Wrote:Works, thanks!
-edit-
Just found another issue (feel like i'm nagging now )
When I press the I button next to the channel name and press the record button (I at least assume it's a record button) next to a show I get an error that my XBMC doesn't support JSON extensions. This is with both before and after the patch for fixing recording.
Log: http://pastebin.com/3B8LbeZU
Grate
Yes that's a recording button. I will check it out whats wrong in a while
but I think it's a app bug this time :/
idioteque Wrote:Hi I love the app but I have a question about the manage functions. None of the mange functions seem to work for me. I'm running a pre Eden build of December 11 410C947
Just Hold the button
and w8 until the blue line fills the button rectangle
mapelli0 Wrote:Hello,
Ty
Alf
What version of XBMC are you using ? and on what device
Ipad2
Xbmc 11.0
Git: 20111210-f1ae0b6
I just upgraded for the nightly build.
But I wasn't working on some other build after the update of constellation
Xbmc remote for android works fine
Archigos Wrote:I got a suggestion from one of the other beta testers and just figured I'd let everyone chime in with thoughts.
I currently host a private forum for the Beta Testers of Constellation but it was suggested to possibly open this forum to all Constellation users (with the beta stuff still private) since this thread is getting more bloated day by day. If I do this, essentially all bug reports, suggestions, etc. would (preferably) be posted there allowing easier search for users before posting the same questions/comments. Most of the other HTPC related sites/apps are starting to provide dedicated forums, if they didn't have them from the start.
Let me know what you guys think. If it's decided to do this, it may take a day or so for me to make the changes to the forums before I make the link public here.
Did we get any answers on the questions above? Do you guys think it's a good idea to provide support on a dedicated forum?
I'm for it as sifting through a 100+ page thread for answers repeated 4 or 5 times is a bit frustrating!
Burbulence Wrote:Did we get any answers on the questions above? Do you guys think it's a good idea to provide support on a dedicated forum?
Not sure if it's sad or ironic... but didn't get a single comment either way (except the original PM that made me suggest it). I think I'll make the changes on the forum anyway and have Dawid edit the first post here to include the link. Probably wont get around to it for a few days though since I'm busy with a lot of stuff.
Archigos Wrote:Not sure if it's sad or ironic... but didn't get a single comment either way (except the original PM that made me suggest it). I think I'll make the changes on the forum anyway and have Dawid edit the first post here to include the link. Probably wont get around to it for a few days though since I'm busy with a lot of stuff.
That's why I threw up the re-post... Youve got my support with it anyway! Lemme know where or if u need my help
any idea if the onscreen remote will be fullscreen at one point (thus not showing the albums beneath) and if there is a way to use this in portrait. Considering to buy this, but some things are not 100 percent to my liking. Is this the best remote app today?
lapino Wrote:any idea if the onscreen remote will be fullscreen at one point (thus not showing the albums beneath) and if there is a way to use this in portrait. Considering to buy this, but some things are not 100 percent to my liking. Is this the best remote app today?
I haven't heard anything about them making the remote part be full screen... and it's pretty much the 'right size' for the amount of buttons it has/uses.
Portrait mode is too narrow across to accommodate things as nicely... (I haven't asked about it, so don't rule it out).
As far as if it's the best, that's a matter of personal opinion... I love it and many of the other users here do as well, but I've never been the type of person that says "Yeah, this is perfect, spend your money" cause my luck it bite me in the @$$. I would highly recommend it though.
