Neutron69ch Wrote:First: great work FSS-Guy's! This XBMC-Remot are a wonder!! Fu** iTunes for ever, no more this dummy-tool from apple.
Second: I'have over my X-Mas-Hollyday's all my MP3 tagged with ID3-Tag's (with MP3Tag). It looks sooooo great! I musst allways play with my iPad(1) and I discover my music-libarery new.
But now I have a small problem. I have an aestethic eye Under constellatin in the tap artist are not all pictures from the right artist displayed. 90% are okey but it have some specials entries they are without an pic. Now have I under XBMC self, they insertd. But constellation will they not take over /accept. What can I do? (for example: one republic, Timbaland, Mattafix, ... are without a picture or the french artist "alizée" become the picture from Aliceé Coper - not realy the same )
the rest is incredible!!
PS: when you looking for person's how test newer beta-version's so let my now.
Greetings from Switzerland
First: I agree about iTunes
Second:
> If you had the music in your library in XBMC before you fixed the images (and tags for that matter), your best bet is in XBMC do a clean of the music database just in case (remove bad stuff) then in Constellation, touch the Cog icon and remove the database, give it a minute to do that, then either close and reopen the app to sync again, or go to Music, Movies, TV, one at a time and pull down far enough to sync each one.
> If that's not the case, or you just want to try this first, touch the Cog icon and Flush image cache, then allow it to sync again to fix the images.
> If neither of the above work and you still have some blanks, check the dimensions of those images... if they're huge, try to resize them to something smaller... otherwise, post back with some more detail or PM me and we can try to figure it out.
BBrian Wrote:I didn't like how I had to pay for the iPhone app and the iPad app. Like, who has an iPad and doesn't have an iPhone? I'd rather click once and enter my password once than twice.
Just bought it the other day when my girlfriend gave me an iPad. Very MTV Cribs. I was so impressed I showed you with my money.
Which version did you try to pay for first, iPad or iPhone? If you bought the iPad version first, you should have been able to just restore that purchase ("Go Pro" -> "Restore Purchase") on the iPhone to get it. If you bought it on the iPhone first, there were two options... The cheaper one was to unlock ONLY the iPhone, the more expensive one (same price as on iPad) would unlock for both using the "Restore Purchase" option on the other device.
P.S. I had an iPad for almost a year before I got my iPhone (had to wait for the CDMA iPhone)
jfreud Wrote:Appletv (black, silver remote) - xbmc pre-11, june
Constellation 1.9.1 on ipad 2
All media on nas, accessed using smb (username and password)
The remote works (most buttons) but status is always "nothing is playing". No movies shows up. Tv series shows up but no episodes are listed.
Http is green, json has no status indication.
Followed all instructions in the youtube-clip.
Xbmc works great on the appletv, the movie library is working with fan art etc.
Any ideas?
Kind regards
/J
First, you should try to update to a newer version of Pre-Eden (there have been a LOT of JSON changes, among other things, since June). After you update, that 'should' solve most, if not all of your problems... but if it doesn't, it may be a router or firewall issue (doubtful, but possible).
deuce Wrote:Bump
Plus :
1- Audio track switch does not work
2- Is that the 'resume' button ? Actually, a howto or changelog would be very usefull ...
1- Last time I checked, Audio Switch worked for me (not on every movie that had multiple audio, but most)
2- That button is for Continuous Play (Example, touch that on a S01E01 file and it will start the beginning of the season and keep playing in order until you stop it).
