Full Version: XBMC Constellation For iPad/iPhone by FSS.cc (unofficial remote)
noumenon Wrote:anybody know how to get the popup that says "detected new connection" to turn off? Everytime I turn on or off my ipad it pops up on the screen. Doesn't seem to matter what skin i'm using. Can't find a setting for it in network preferences.
thanks,
noumenon
Go to the general settings of your iPad, select Constellation in the list and disable the notify option.
Didn't even think to look in the iPad settings. Thanks for the heads up.
I got an idea for a useful feature.
It would be great to be able to add Movies to the favourites.
Great app, I bought the pro for iPhone version, then at Xmas got a pad and got the pro for that. However my first pad has just been exchanged due to a fault and I am back to ads on my new pad, do I have to pay again as seems to be the case when I try to restore full version through the app store?
Cheers Dan.
Hi
Just found this app yesterday.
Fantasic app, i've been up all night testing it Smile
I'm running XBMC 10.1 on XP and i have an ipad2
I have opened up the ports listed, i have both green lights.
There are a couple of things not working.
-Youtube, i can play on the ipad, but unable to send to my tv
-Weather script is crashing
-I can't open pictures when going into the files folder, when pressing nothing happends, if i use remote function it works as normal.
neffets Wrote:Hi
1.) To send YouTube videos from the iDevice to XBMC you need a version that supports AirPlay in XBMC (an Eden Only feature).
2.) Weather is broken in pretty much every version of XBMC prior to Eden... Check HERE and HERE for more details.
--Edit--
3.) If you're talking about going into "Files" -> "Pictures" and navigating to an image. After you touch the image, you have to hit the Play button for that image. If it doesn't work, it's probably just not supported properly in 10.1.
Ok, i think I will wait for the finall release of Eden before i upgrade.
Thanks a lot for quick reply Smile
Cheers Burbulence, back to pro now.
also just come across this app
looks great!
was just wondering with the youtube functions was there the ability to log into your own account to watch favorites and subscriptions etc...
if not is this something that might be added down the track??
thanks
Works excellent since the last update!
One question regarding the movie sets:
I like to only see the not watched movies in my list however the movie sets still display when all movies belonging to that set is watched.
anyone have an issue with Cinema Experience ?
for me Cinema Experience is working OK directly on Eden, but I cannot run it from Constellation Sad
Archigos Wrote:1.) To send YouTube videos from the iDevice to XBMC you need a version that supports AirPlay in XBMC (an Eden Only feature).
Can't remember if it works with 10.1 but if you click on the play button with the monitor/tv icon on the bottom left side of the YouTube screen then it should send the link To xbmc and play directly...
@ Archigos
I think after the last few questions we need to get the button descriptions started!?
castortray Wrote:anyone have an issue with Cinema Experience ?
here
NaDs Wrote:also just come across this app
looks great!
thanks
If the devs get time they will add this feature
