Hello, first off I'd like to say I love the XBMC software. I've paid for many other media libraries and this is the only one that cut it (plus it's free!)
I downloaded Constellation the other day and I'm completely stumped as to getting it to work.
My Constellation version is 1.9.1 on the iPhone 4S version 5.0.1
My XBMC is version 10.1 with the Aeon Nox skin
My HTPC is a Windows 7 PC
My router is a Linksys E3000 with firmware version 1.0.01
On XBMC I've enabled control through HTTP
-Port: 8080
-Username: xbmc
-password: none
I've allowed both programs on this system and other systems to control XBMC.
On Constellation my settings are matching.
The Host is my HTPC IP address, which is 192.168.1.50
Port: 8080
Username: xbmc
Password: none
Event Server: on
In Linksys I've disabled it's firewall and forwarded ports 8080, 9090, and 9777 for the HTPC IP.
I've disabled my Windows Firewall and turned off all of it's rules for good measure.
I've disabled firewall/antivirus from Iobit and turned off all of their rules.
I also turned off UAC.
When I use a web browser to access
http://192.168.1.50:8080 on my HTPC it works fine and connects to XBMC.
If I do the same on my iPhone, or even my iPad, the server times out.
When I try and use the Test button on Constellation, I get the following error
"Error
- Please check your IP/host settings. If those are correct, check if the XBMC interface is up and running by opening it's web page in the browser
http://192.168.1.50:8080"
I'm completely stumped, I feel like I've tried everything, I'm not sure what else I could tweak. It's as if something on my HTPC is blocking incoming connections, but I have no idea what it could be.
If anybody could help me out, you'd be my hero!
