(2012-03-13, 15:44)subvertbeats Wrote: [ -> ]unfortunately the issue persists with AV disabled
What port is xbmc using out of interest? System> settings> network
Is it possible to view lyrics on constellation. Thats the only feature I miss.
Regards
(2012-03-13, 23:14)Burbulence Wrote: [ -> ] (2012-03-13, 15:44)subvertbeats Wrote: [ -> ]unfortunately the issue persists with AV disabled
I have it running on 8088
Would it ever be possible to add an option to the settings where WOL, Suspend, Reboot and that are to send an SSH command using a Key Pair or a simple bash script?
The SSH command im thinking off is "pkill -9 xbmc,bin" in the case of an xbmc freeze the JSON stops responding so if the iphone is the only input device for the HTPC you have to press the power button
cheers Jon
Hello there, Dawid!
Just bought your app and after a days of fiddling about with it i must congratulate you - this is really a piece of work you and your colleagues have done. Thanks for that. One thing i've found funny tho - i cant seem to get a HTTP connection with my HTPC while it is running the utorrent client. The remote control works, also the server responds with "A remote device has been connected" or something like that, but no playback progress tracking, no media library, nothing else works. I've tried disabling various functions on the client, varying from disabling DHT to turning off the web-interface, all to no avail. Could you give some tips on what i might be doing wrong? Even with zero load on bandwidth from the P2P client your app isnt connecting.
Constellation is accessing the HTPC via 192.168.1.100:8080. My LAN network is based around a Cisco WRT610N router, the HTPC is wired with an RJ45 (isnt that the correct calling of Ethernet?), hope that helps!
@thelos,
Check your ports, 8080 for http unless you changed it setting up the app, 9090 for json, you can't change this port right now
(2012-03-14, 12:04)subvertbeats Wrote: [ -> ] (2012-03-13, 23:14)Burbulence Wrote: [ -> ] (2012-03-13, 15:44)subvertbeats Wrote: [ -> ]unfortunately the issue persists with AV disabled
Burb - your post got me thinking, and I think I've found the issue (at least here)
When XBMC is running on http port other than 8080 (and you configure constellation appropriately) I get that JSON problem.
Change the XBMC http port to 8080, and update the config in constellation, and the app holds the JSON connection
(2012-03-15, 10:24)subvertbeats Wrote: [ -> ]Burb - your post got me thinking, and I think I've found the issue (at least here)
Great news, it had to be a port conflict,
Burb, theres something going on with the app.
Change the HTTP port, and JSON connection fails.
There is nothing else running on either 8080, 8088, or 9090
Config 1: FAIL - HTTP connection established, JSON connection fails
HTTP port: Anything other than 8080 (eg 8088)
JSON port: 9090
Config 2: SUCCESS
HTTP port: 8080
JSON port 9090
Burb, about the issue with utorrent:
I've disabled almost every feature in utorrent, the web UI is off, DHT is off, UPnP port mapping is also off, NAT-PMP is turned down.All the features from "Bittorrent" tab are also off. The utorrent port in use is 37689, the 8080 and 9090 are definetely not in use.
The issue persists anyways. And as soon as i turn off utorrent the connection resumes almost immediately. I'm running the Eden RC2 on a clean W7 build. Any ideas?
(2012-03-15, 17:23)subvertbeats Wrote: [ -> ]Burb, theres something going on with the app.
JSON port: 9090
Config 2: SUCCESS
HTTP port: 8080
JSON port 9090
it 'could' be a glitch in v1.9.1... im running the v2 beta, which works if you change ports... ive never come across it before mainly as ive never run on a different port!!
Theolos on one of my posts i think on the page before this i posted a link to a prog that will list all ports in use,
run it on your computer to see which ports are being used when utorrent is running normally, with xbmc closed
Burbulence:
I've solved the issue, despite the app saying that the http port was okay, changing it from 8080 had helped. Changing the json rpc didnt help, as it was the http issue. Thanks for your patience, i've noticed that such questions appear often and can make it a pain in the ass for support.
(2012-03-15, 20:57)Theolos Wrote: [ -> ]Burbulence:
It's all good, although you should head over to the constellation forum for support, it's easier than trying to sift through a 130+ page thread!
Hi all, I'm coming to the forum .... and I wonder if the version 2.0 have you ever asked!
Ability to search a video on youtube and put on the list ... Example: This playing a video ... I search there and put another in the Skins in the list of next ... and so on! has the?
(2012-03-16, 04:55)iorifly Wrote: [ -> ]Hi all, I'm coming to the forum .... and I wonder if the version 2.0 have you ever asked!
Check out the
Facebook page, Dawid has some spoiler photos of whats to come in v2.2
