Hi Guys
I'm probably one of your only paid users whom still uses one of the original iPhone 3g (not the 3gs!)
It looks like the app no longer supports IOS 4.2.1; And the constellation app on my phone seems to be v1.9.1.
I run an old ATV v1 with crystalbuntu - which has just updated to XBMC 11.0 EDEN final.
Constellation has worked perfectly so far on the phone with the earlier XBMC eden beta drops.
I'm just wondering if v1.9.1 properly supports EDEN 11.0?
What am I missing out with in terms of Constellation 2.1 etc ?
Thanks a lot for this wonderful app, which I bought as it will most probably make me change from MediaPortal to XBMC in the near future.
I am using Constellation for two days now and everything works fine except for the TV part: The EPG is loading fine but I cannot watch a TV show from it: There's no xbmc reaction when I press the show and then the Switch button.
Is this supposed to work in my installed version (5)? How can I help to find a solution?
I am using margro's eden final PVR build and: Watching TV works by using the Constallation remote functionality.
Thx a lot, G.
I was testing it and noticed the same, but then I also noticed that you put most of the pvr stuff in the paid version only, and I'm not going to pay to debug my own stuff
(2012-03-27, 14:17)GoldenEye Wrote: [ -> ]Thanks a lot for this wonderful app, which I bought as it will most probably make me change from MediaPortal to XBMC in the near future.
Thx a lot, G.
(2012-03-27, 21:44)dushmaniac Wrote: [ -> ]I was testing it and noticed the same, but then I also noticed that you put most of the pvr stuff in the paid version only, and I'm not going to pay to debug my own stuff
dushmaniac-->PM
Sorry the switch is not mapped in the new version we don't have a beta tester with PVR
so stuff like this happens. I'm the only one with a PVR setup
This is fixed in v 2.2 witch is @ the finish line
should be submitted to appstore by the end of this week.
You can switch channels by pressing it's name on the left table (with the channel names)
Regards
(2012-03-26, 18:08)markswift Wrote: [ -> ]Hi,
I am using the latest version on an iPad 1 (Shows as Version 5 in the App settings).
My XBMC installation is on the same system as the drives. I am using Version 11 Final. The folder layout is as follows:
Drive / Movies / Movie Name [Year] / Movie Name [Year].extension
Metainfo is obtained using the built in scraper. All movies appears in XBMC Commander without issue and on the web interface, they also appear in XBMC Constellation using any filter but 'label'! I've also tried a complete restore of the iPad which made no difference.
Mark
(2012-03-25, 22:47)Burbulence Wrote: [ -> ]We have just found the problem It will be fixed ASAP
(2012-03-25, 09:32)DaPhatty Wrote: [ -> ]I must be doing something wrong because I can't find this option. Closest option I've found is called Override Lockscreen. What am I missing? I am using the latest version of Constellation on an IPad 2 with iOS 5.01.
Enable It and start a movie Lock your device
I think lock screen integration was added by apple in ios 5.1, (camera) thatll be why you can't see the option.
Id like to point out the constellation forums again... linked in my sig... I want to help you guys and the info being discussed over there makes it easier to find than all crammed into 1 thread here!
(2012-03-25, 20:39)markswift Wrote: [ -> ]Am I the only one with missing movies then? This seems odd as all other XBMC apps work fine and display all movies.
The strange thing is the movies appear in the dashboard and when the filter is set to anything but 'label'.
Hope this can be solved!
You a seem to be the only 1 with this problem I'm scratching my head trying to reproduce it, can you provide a break down of your system, usefull screenshots how you have your movies organised, basically how you go from new movie file to seeing it in your library,
(2012-03-27, 08:30)Tamassa_974 Wrote: [ -> ] (2012-03-26, 18:08)markswift Wrote: [ -> ]...All movies appears in XBMC Commander without issue and on the web interface, they also appear in XBMC Constellation using any filter but 'label'!...
I have the same problems.
I'm using xbmc 11.0 and constellation on ipad2.
(2012-03-27, 09:48)NaDs Wrote: [ -> ]any chance on making a different view in the youtube section like the youtube app
this could be thumbnail view (you would fit more videos onto the screen without scrolling) pretty much just bigger thumbnails....
this could be list view
could this be something we could add??
Later on will will introduce something like this I think you will like it
(2012-03-27, 12:34)herod98 Wrote: [ -> ]Hi Guys
Well we had to raise the os version to block the old iPhone 3g as The new layout is really hard for that phone and some ppl are complaint afterwords that It Glitches... You are not missing much if you don't use live tv in terms of functionality of course the 1.9.1 is still fully operational with eden.
Bought the app a few days ago and liking it a lot.
Just wondering if you are planning to add the ability to display the folder.jpg images when browsing folders via the "Files" option?
Added to the ToDo list
Regards
After updating to XBMC Eden 11.0 release I also get the error that Constellation does not load images anymore. ( Like Cokecan72 described here earlier, and bigdog66 in the Constellation forums)
Tried reinstalling Constellation, still no images. I get green lights on the connection status, looks ok. If I connect to my xbmc via the browser all images are shown, works ok.
I have now reverted to XBMC Eden RC1 (with PVR) , and now Constellation loads the images again. So is there a bug in xbmc 11.0 Final? Did the http/json handling change in the last versions? Or is Constellation using an old protocol?
How about resolving the bugs from users whom were amongst the first to go pro :-(
Currently I'm using an alternative product.
It also appears I'm not the only one experiencing the missing movies issue I've reported numerous times (see tamassa 974 comment on previous page).
Mark
(2012-03-27, 23:10)FSS_Dawid Wrote: [ -> ]Added to the ToDo list
Regards
(2012-03-28, 21:31)Sabbi Wrote: [ -> ]After updating to XBMC Eden 11.0 release I also get the error that Constellation does not load images anymore. ( Like Cokecan72 described here earlier, and bigdog66 in the Constellation forums)
Do you use a password for the web interface ? Can you try leaving only the user name...
We have tried to reproduce the missing thumbnail problem on osx windows Linux openelec with no luck I have even got a db file and the thumbnail folder from a user that has the same problem and it works
(2012-03-28, 21:38)markswift Wrote: [ -> ]How about resolving the bugs from users whom were amongst the first to go pro :-(
Mark
Regards
Sorry for your disapoitment we are doing everything we can. The version that was submitted to AppStore should resolve the problem. Can you give me some sample titles and tell me what scraper are you using ?
(2012-03-28, 22:01)FSS_Dawid Wrote: [ -> ] (2012-03-28, 21:31)Sabbi Wrote: [ -> ]After updating to XBMC Eden 11.0 release I also get the error that Constellation does not load images anymore. ( Like Cokecan72 described here earlier, and bigdog66 in the Constellation forums)
I do use a password on my xbmc, just tried empty password and also empty username & password, still no go.
I'm running xbmc on Atv1 with Crystalbuntu, thanks for the quick reply anyway
(2012-03-22, 15:38)castortray Wrote: [ -> ]Hi dev team,
Do you plan add possibility to search movie by actor ? As this function already exists in xbmc.
Can you pls add this festure to ToDo list ?
I have searched this site and Google and can't find a satisfactory answer. Can I display 1channel/icefilms in a GUI on my iPad? By that I mean display thumbnails for movies in the addon(s).
This may have been addressed in the forums already, but I have an iPad 3 and scrolling through movies and tv shows stutters a bit. Not enough to make it unusable, but it definitely takes away from the nice polished look of this app. I'm a pro user and would be very pleased if it were possible to smooth out this rough spot.
