Hello my NEON-skin friends
First of, i LOVE this skin. It is really awesome.
Second I have 2 question:
1. How do i know that i have the latest updated skin?? Or how do i update it??
2. When i added the new episodes of Futurama it didn´t find them. What shall i do so it can find them?? Must i change the scraper??
Thanks for everything.
If you are using a nightly build of XBMC, then your best bet is to install the Passion Repo and download the skin from there. Info on 3rd party repos can be found here:
http://wiki.xbmc.org/index.php?title=Uno...positories
If you are using the official release from xmbc.org, you will just have to wait until I update the 10.1 build, hopefully in the next couple of weeks.
As for Futurama, the key with all tv shows is to ensure the files are named correctly, showname.sXXeYY.whatever.ext where XX is the Season and YY is the episode. Having said that, I just checked thetvdb.com site and there look to be issues with Season 7 of Futurama...
Hi stoli
Great skin, love it
Sorry to bother you with these questions but how do i install the Passion Repo
I found it but where should i put it
And i got the skin from there 2, and where should i put that
I don't want to sound like a dick, but there are step by step instructions on that page I linked above....
Man i am so sorry hahaha. I wasted your time. Thanks for the link anyways and keep up the good work on Neon.
P
Hello stoli again
I checked the thetvdb.com about Futurama and the new episodes is for season 6, episode 14, 15 and 16 are there. All the information.
But when i make a search it can´t find them in my library. It has found all my other tv-shows.
Thank you
Even though this isn't a skin question.... What are your filenames for the episodes that won't scan
Futurama.s06.e14.720p.HDTV.X264-groupname
PanMan79 Wrote:Futurama.s06.e14.720p.HDTV.X264-groupname
I think removing the "." between your "s06" and "e14" will do the trick.
Ok zoso i will try that when i get home from work.
Thanks everybody
Just wanted to add that I installed the repository app & went over to passion to get latest SVN of Neon, but it is listed as broken =(
Are you running a nightly xbmc build or 10.1? If you are using the svn version of the skin it requires a nightly...
Don't know then. Grab it from git - github.com/Stoli. (I think that's right)
stoli Wrote:Don't know then. Grab it from git - github.com/Stoli. (I think that's right)
I don't know why, but it has been listed as broken in the passion repository for a while now, even though you can manually download it from passion and install it with no problem.
While it is great that the skin works, it is a pain to have to manually download it when I would like to update the skin.
Do you think PM'ing ppic (I think he is the admin of passion) would help resolve the issue?
