Full Version: mp4 playback issue
I've a lot of mp4 videos that i encoded a while back to play on my ipad. Problem is XBMC cant play them, they stutter like crazy. Although it's not the case with all of them, only most. From what i can tell, it must have something to do with 'AVC baseline'
Here is a mediainfo example of one that doesn't work...
General
Complete name                    : E:\Movies and TV\TV Shows\Archer\Season 01\01 - Mole Hunt (Archer (2009).s01e01).mp4
Format                           : MPEG-4
Format profile                   : Base Media / Version 2
Codec ID                         : mp42
File size                        : 173 MiB
Duration                         : 21mn 0s
Overall bit rate                 : 1 152 Kbps
Movie name                       : Archer
Track name/Position              : 1
Track name/Total                 : 0
Genre                            : Animation
Encoded date                     : UTC 2010-07-01 23:17:27
Tagged date                      : UTC 2010-10-08 15:27:25
Writing application              : mp4creator 1.4.4
tvsh                             : Archer
tven                             : 101
tves                             : 1
stik                             : 10
tvsn                             : 1
Xtra                             : WM/MediaClassPrimaryID
Video
Format                           : AVC
Format/Info                      : Advanced Video Codec
Format profile                   : [email protected]
Format settings, CABAC           : No
Format settings, ReFrames        : 2 frames
Codec ID                         : avc1
Codec ID/Info                    : Advanced Video Coding
Duration                         : 21mn 0s
Bit rate mode                    : Variable
Bit rate                         : 1 024 Kbps
Width                            : 624 pixels
Height                           : 352 pixels
Display aspect ratio             : 16:9
Frame rate mode                  : Constant
Frame rate                       : 24.000 fps
Resolution                       : 8 bits
Colorimetry                      : 4:2:0
Scan type                        : Progressive
Bits/(Pixel*Frame)               : 0.194
Stream size                      : 154 MiB (89%)
Language                         : English
Tagged date                      : UTC 2010-07-01 23:17:30
Audio
Format                           : AAC
Format/Info                      : Advanced Audio Codec
Format version                   : Version 4
Format profile                   : LC
Format settings, SBR             : No
Codec ID                         : 40
Duration                         : 21mn 0s
Bit rate                         : 126 Kbps
Maximum bit rate                 : 251 Kbps
Channel(s)                       : 2 channels
Channel positions                : Front: L R
Sampling rate                    : 44.1 KHz
Stream size                      : 18.9 MiB (11%)
Language                         : English
Encoded date                     : UTC 2010-07-01 23:17:30
and one that does...
General
Complete name                    : E:\Movies and TV\TV Shows\American Dad!\Season 02\02 - A Smith in the Hand (American Dad!.s02.e02).mp4
Format                           : MPEG-4
Codec ID                         : isom
File size                        : 129 MiB
Duration                         : 21mn 55s
Overall bit rate                 : 825 Kbps
Movie name                       : 09 - A Smith in the Hand   [American Dad!.s01e09]
Track name/Position              : 9
Genre                            : Animation
Tagged date                      : UTC 2010-10-08 16:29:23
Writing application              : Lavf52.33.0
tven                             : 109
tves                             : 9
stik                             : 10
tvsh                             : American Dad!
tvsn                             : 1
Video
Format                           : MPEG-4 Visual
Format settings, BVOP            : No
Format settings, QPel            : No
Format settings, GMC             : No warppoints
Format settings, Matrix          : Default (H.263)
Codec ID                         : 20
Duration                         : 21mn 55s
Duration_LastFrame               : -41ms
Bit rate                         : 756 Kbps
Width                            : 480 pixels
Height                           : 360 pixels
Display aspect ratio             : 4:3
Frame rate                       : 23.976 fps
Resolution                       : 8 bits
Colorimetry                      : 4:2:0
Bits/(Pixel*Frame)               : 0.182
Stream size                      : 118 MiB (92%)
Writing library                  : Lavc52.29.0
Audio
Format                           : AAC
Format profile                   : LC
Codec ID                         : 40
Duration                         : 21mn 54s
Bit rate                         : 64.2 Kbps
Sampling rate                    : 48.0 KHz
Stream size                      : 10.1 MiB (8%)
Here's the debug log...http://pastebin.com/VDCau9gm
bump
If you want to put an example mp4 somewhere I can download and test it I'd be happy to take a look.
Your best bet would be to take one of the problematic mp4s and recode it with Handbrake or something similar to see if that makes a difference.
Later: I've just seen http://forum.xbmc.org/showthread.php?tid=104677 and this looks similar to your problem.
JR
probably you have no HW acceleration decoding enabled or the libs required installed, a little more information about video cards and general hw would be nice.
