2011-07-01, 22:43
Whatsup!
So im getting ready to do my first XBMC setup for my own home media center. Im going to use XBMC because... well it just seems like the best option.
Im a linux systems engineer, so im pretty damn good with software, I just dont usually do the hardware bit, Lets leave that bit to the NOC ;-)
Im going to install ubuntu 9.04 because that seems to be the most popular, the pandora plugin only works on there (according to my research), unless you can tell me it works on 10.x or 11.x. I got that info from here: http://forum.xbmc.org/showthread.php?tid=70471
Now it looks like streaming from a NAS is pretty straight forward, for music and videos, so no worries about that, but I do also want to stream Cable TV to it as well, and use multiple Capture Cards. This is where I have a few questions....
1) I see that the MythTV is whats used for DVR, (http://www.mythtv.org/), IM supposing that gets installed on the same server as the XBMC? Or should that go on a different server all together, Id like to have 2 or 3 capture cards.
2) Also, I know I can use the Logitech bluetooth keyboard, but id like to use a real IR remote as well, (more friendly for visitors). After some googling, I see most people use the Hauppauge PVR-150 remote (http://www.mythtv.org/wiki/Hauppauge_PVR-150), which seems to be compatible? That does include a remote, but would the remote also allow you to control everything else? Play music, select videos, etc etc,.... I just want to make sure its 100% compatible.
