Full Version: Newbie just installed XBMC can't play music
I just installed XBMC and connected to my UPnP / DLNA server.
It seems to only play MP3 files. Other formats don't play.
I suppose that there is a problem with the codecs. Or ??
Running on Win7 Pro
Regards
AndrewFG
xbmc plays almost all media file formats without need for external codecs, cause it uses ffmpeg.
I'd guess its your mediaserver trying to transcode the files. Try "no transcode" option.
An even better proof would be to copy a few files directly to the xbmc machine and try to play them locally. this should absolutely work.
wsnipex Wrote:An even better proof would be to copy a few files directly to the xbmc machine and try to play them locally.
Yes this is true. The files do play locally.
The media server offers several versions of the file: original native format, transcoded pcm and transcoded mp3. And XBMC is choosing the pcm version to download. However, it encounters problems actually playing that pcm file. Below is an excerpt from the log file...
15:28:54 T:4236 M:2489655296   DEBUG: CPlayerCoreFactory::GetPlayers(http://192.168.1.100:31416/tid_6280/src_alc/tgt_pcm/pid_4/music.pcm)
15:28:54 T:4236 M:2489655296   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules
15:28:54 T:4236 M:2489655296   DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules
15:28:54 T:4236 M:2489655296   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtv
15:28:54 T:4236 M:2489655296   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: hdhomerun/myth/rtmp/mms/udp
15:28:54 T:4236 M:2489655296   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout
15:28:54 T:4236 M:2489655296   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp
15:28:54 T:4236 M:2489655296   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams
15:28:54 T:4236 M:2489655296   DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: streams
15:28:54 T:4236 M:2489655296   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: flv/aacp/sdp
15:28:54 T:4236 M:2489655296   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: mp2
15:28:54 T:4236 M:2489655296   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd
15:28:54 T:4236 M:2489655296   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdfile
15:28:54 T:4236 M:2489655296   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage
15:28:54 T:4236 M:2489655296   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf
15:28:54 T:4236 M:2489655296   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv
15:28:54 T:4236 M:2489655296   DEBUG: CPlayerCoreFactory::GetPlayers: matched 0 rules with players
15:28:54 T:4236 M:2489630720   DEBUG: CPlayerCoreFactory::GetPlayers: adding audiodefaultplayer (3)
15:28:54 T:4236 M:2489630720   DEBUG: CPlayerCoreFactory::GetPlayers: for video=0, audio=1
15:28:54 T:4236 M:2489630720   DEBUG: CPlayerCoreFactory::GetPlayers: adding player: PAPlayer (3)
15:28:54 T:4236 M:2489630720   DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1
15:28:54 T:4236 M:2489630720   DEBUG: CPlayerCoreFactory::GetPlayers: adding player: DVDPlayer (1)
15:28:54 T:4236 M:2489630720   DEBUG: CPlayerCoreFactory::GetPlayers: added 2 players
15:28:54 T:4236 M:2489618432   DEBUG: Win32DllLoader::Load(special://xbmcbin/system/players/paplayer/vgmstream.dll)
15:28:54 T:4236 M:2489589760   DEBUG: CFileCache::Open - opening <tid_6280/src_alc/tgt_pcm/pid_4/music.pcm> using cache
15:28:54 T:4236 M:2489589760   DEBUG: FileCurl::Open(0722C4C8) http://192.168.1.100:31416/tid_6280/src_alc/tgt_pcm/pid_4/music.pcm
15:28:55 T:2916 M:2489589760   DEBUG: thread start, auto delete: 0
15:29:03 T:2916 M:2450644992    INFO: CFileCache::Process - Hit eof.
15:29:03 T:2916 M:2450702336   DEBUG: Thread 2916 terminating
15:29:03 T:4236 M:2450702336   DEBUG: FileCurl::Close(0722C4C8) http://192.168.1.100:31416/tid_6280/src_alc/tgt_pcm/pid_4/music.pcm
15:29:03 T:4236 M:2460565504   ERROR: VGMCodec::Init: error opening file http://192.168.1.100:31416/tid_6280/src_alc/tgt_pcm/pid_4/music.pcm!
15:29:03 T:4236 M:2460569600   ERROR: CAudioDecoder: Unable to Init Codec while loading file http://192.168.1.100:31416/tid_6280/src_alc/tgt_pcm/pid_4/music.pcm
15:29:03 T:4236 M:2460557312   ERROR: Playlist Player: skipping unplayable item: 0, path [http://192.168.1.100:31416/tid_6280/src_alc/tgt_pcm/pid_4/music.pcm]
