Full Version: content type in files node
I've been a bit confused about this.
When I go into the video files node, and then into one of the sources that is also present in the library, should the content type be "files" or "movies/tvshows/etc" ?
I have conditions set up to display controls when entering from the files node, and these aren't working anymore. They used to work because the content type would be files regardless of whether a source was present in the library, which makes sense imo.
nope you can only have one content type at a time and they are movies/tvshows/etc if they are set but the bonus too it is it can display all the data that the library nodes can anyway
Files is really only anything that has no content set
Thanks, I'm pretty sure it was working not too long ago though. Anyway, managed to find a way to get it the way I want again Smile
