I can't get my diseqc 2.0 working in VDR.
I know VDR is working because straight to the LNB works (watching tv is ok) but with diseqc between its not.
It seems that the diseqc switching does not work at all.
Setup.conf has diseqc=1
My Sources.conf and Diseqc.conf has the same S names.
I've tried numerous diseqc.conf variants.
Is diseqc 2.0 supported in S2API drivers for my technotrend s3650-usb ? (stb0899/6100)
Any ideas?
Yes, diseqc supported in S2API drivers for technotrend s2 3650 ci. I used to own this card when it first came out. It died after 8 months of usage, i was the first person that used in linux. Now i own a tevii DVB-S2 USB Box (S650) and i still use the same config.
my diseqc.conf:
# Input 1 - Thor
S0.8W 11700 V 9750 t v W15 [E0 10 38 F0] W15 t
S0.8W 99999 V 10600 t v W15 [E0 10 38 F0] W15 T
S0.8W 11700 H 9750 t V W15 [E0 10 38 F0] W15 t
S0.8W 99999 H 10600 t V W15 [E0 10 38 F0] W15 T
# Input 2 - Sirius
S4.8E 11700 V 9750 t v W15 [E0 10 38 F4] W15 t
S4.8E 99999 V 10600 t v W15 [E0 10 38 F4] W15 T
S4.8E 11700 H 9750 t V W15 [E0 10 38 F4] W15 t
S4.8E 99999 H 10600 t V W15 [E0 10 38 F4] W15 T
# Input 3 - Hotbird
S13.0E 11700 V 9750 t v W15 [E0 10 38 F8] W15 t
S13.0E 99999 V 10600 t v W15 [E0 10 38 F8] W15 T
S13.0E 11700 H 9750 t V W15 [E0 10 38 F8] W15 t
S13.0E 99999 H 10600 t V W15 [E0 10 38 F8] W15 T
# Input 4 Astra 1 19.2E
S19.2E 11700 V 9750 t v W15 [E0 10 38 FC] W15 t
S19.2E 99999 V 10600 t v W15 [E0 10 38 FC] W15 T
S19.2E 11700 H 9750 t V W15 [E0 10 38 FC] W15 t
S19.2E 99999 H 10600 t V W15 [E0 10 38 FC] W15 T
S2-liplianin just not seems to support diseqc 2.0 switches
Under Windows it works like a charm, but I refuse to use that OS ;-)
You should ask questions like this on vdr-portal.de. There are lots of people who have experiences with exactly this hardware and Diseqc.
Cheers,
hepi
Thanks hepi, I'm gonna give it a try...
