I've mostly been using Fusion Migma v2.
Which skin has the most options to configure?
Also if I change some settings on a skin then try a different skin but go back to the first skin will the settings I changed have reverted back to their default? Or I'll my changes still be there?
(2012-05-28, 03:23)ClayM Wrote: [ -> ]I've mostly been using Fusion Migma v2.
Your showing DTS HD Master flags? I'm only getting DD and DTS flags, no HD flags.
I'm sure that this has been asked quite a number of times, but the comparison wiki doesn't seem to be up to date at the moment. Which skins are the most feature rich including custom home entries, live tv, etc?
Thank you
Hardware limitations aside, what would be the consensus on the skin with the most wow factor/eye candy/bling? Aeon Nox? Fusion? Xperience1080?
I would have to say at the moment Aeon Nox 3.0!!!!!!
reFocus BIG is the one I like the most.
Aeon Alaska is SUPER nice. Great combination of the slickness of Alaska and Aeon.
(2012-07-24, 00:59)patseguin Wrote: [ -> ]Aeon Alaska is SUPER nice. Great combination of the slickness of Alaska and Aeon.
Where is the "Aeon Alaska" skin? I searched but couldn't find it.
On the ATV 2, I like Rapier.
Not too heavy, still pack with lots of options.
I think a lot of this discussion will come down to the element of, "best skin per platform".
Would like to know what others on ATV 2 are using.
How does the performance of Aeon Nox compare to Aeon MQ? On a mid range htpc. I believe these are the 2 most 'heavy' skins with lots and lots of options and rich views.
re-Focus Big. Cleanest/smoothest skin around.
(2012-07-22, 21:08)Myrddraal Wrote: [ -> ]reFocus BIG is the one I like the most.
(2012-07-26, 04:10)knewknow Wrote: [ -> ]re-Focus Big. Cleanest/smoothest skin around.
+1
Yeah, refocus BIG is really good. Fast and pretty.
I really wish someone would make an aeon nox version with a vertical home menu. I hate not having all options at glance on the home screen and have to scroll around :S
