1. Many of my TV show seasons don't show up
2. The icon for the weather is constantly flashing
3. While options for TV settings seem to show up I can't select them
Any ideas on how to fix any of those?
OutOfExile Wrote:3. While options for TV settings seem to show up I can't select them
Unless you are running the PVR branch of xbmc, there are no options for TV settings, so that is normal.
For issue #1, do they show up in other skins?
OutOfExile Wrote:Yeah
interesting...can't think of a sole reason why that would happen...
maybe you're using filemode in one skin and library mode in Transparency!?
or maybe you have 'hide watched enabled it T!'?
that's the only reasons i can come up with...
please post a
Debug Log (and preferably some screenshots of both skins) if the issue persists.
issue #2:
several users have
reported it, but i can't reproduce it.
i have created a ticket for it:
http://trac.xbmc.org/ticket/11501
ronie Wrote:interesting...can't think of a sole reason why that would happen...
please post a Debug Log (and preferably some screenshots of both skins) if the issue persists.
issue #2:
several users have reported it, but i can't reproduce it.
i have created a ticket for it: http://trac.xbmc.org/ticket/11501
ronie,
I had this issue in my skin (issue #2). Went away when I made sure that the labels had a width and height tag set. Have a look at the offending label and see if you have set these values or if you are relying on default values as I was.
Wyrm (xTV-SAF)
Ronie, sorry thought original post said labels, not images. Go have a check just the same as maybe related
wyrm Wrote:Ronie, sorry thought original post said labels, not images. Go have a check just the same as maybe related
no worries and thanx for your input.
i've double-checked my multiimage controls but there's nothing wrong wth them.
it's most likely the Textures.xbt file that's screwed, but i can't reproduce it and none of the devs so far either, which makes it hard to fix.
