2011-07-05, 12:26
Hi all,
I'm not sure if this should go here or on a Mac forum, but I only started experiencing these issues after changing the settings in XBMC.
So, the setup:
I have a 13" MacBook Pro, that I connect to my 50" HD LG Plasma tv through a mini-display port to HDMI. Everything has worked flawlessly for a few weeks, but for some reason () I went in to the audio settings to see if everything should be as it was, and I think I changed something, but I have no idea what -_- I tried changing them back or choosing the most logical settings but it still doesn't work. Output should be HDMI right? I'm not sure what the original setting was.
Anyway, the problem is this, when I plug in the cable and open XBMC I hear the menu scrolling sounds but when I start a movie the sound disappears from the TV. And when I exit XBMC the sound on the computer is instead activated (from my MacBook pro in clamshell mode) so there seems to be something weird going on with the sound settings, because there shouldn't be any sound coming from the computer itself, just the tv. Before the setting change the volume button on my computer used to be muted so that I could only change the volume from the tv (as it should be), but now after I start playing a movie, the volume indicator on the computer is not muted and I can change the level of the volume, but just for the computer sound. This is extremely frustrating. Has anyone had a similar problem? And what are the default audio output settings? Can I change them back somehow?
So, the setup:
